Alsa 1.x and dosbox
First post, by squire_pug
Is dosbox compatible with 1.x release of ALSA ?
getting this error when I try to compile:
make[3]: Entering directory `/home/downloads/dosbox-0.60/src/gui'
if g++ -DHAVE_CONFIG_H -I. -I. -I../.. -I../../include -g -O2 -I/usr/include/SDL -D_REENTRANT -MT midi.o -MD -MP -MF ".deps/midi.Tpo" \
-c -o midi.o `test -f 'midi.cpp' || echo './'`midi.cpp; \
then mv -f ".deps/midi.Tpo" ".deps/midi.Po"; \
else rm -f ".deps/midi.Tpo"; exit 1; \
fi
In file included from midi.cpp:91:
midi_alsa.h: In member function `void MidiHandler_alsa::send_event(int)':
midi_alsa.h:46: `snd_seq_flush_output' undeclared (first use this function)
midi_alsa.h:46: (Each undeclared identifier is reported only once for each
function it appears in.)
midi_alsa.h: In member function `virtual bool MidiHandler_alsa::Open(const
char*)':
midi_alsa.h:143: `SND_SEQ_OPEN' undeclared (first use this function)
midi_alsa.h:150: `snd_seq_set_client_group' undeclared (first use this
function)
make[3]: *** [midi.o] Error 1
make[3]: Leaving directory `/home/downloads/dosbox-0.60/src/gui'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/downloads/dosbox-0.60/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/downloads/dosbox-0.60'
make: *** [all] Error 2
Any Ideas anyone ?
Linux 2.4.25,
AMD 2600 XP - M
512 mb RAM
Slackware 9.1
Alsa 1.03
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
try 0.61 which is alsa 1.x compatible
0.60 is not compatible.
Water flows down the stream
