First post, by Thin_icE
Some days ago I was using dos box with prehistorik 2 and, while increasing the cycles, the program crashed and I had to reset the pc (with the cycles really high), and now, everytime i boot the pc, the "explorer" task takes up 100% of the CPU. Is there a way to correct this without formatting the hard-drive? Plz help 😖
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
explorer 100 % while not running dosbox....
hmmm run a virus scanner and windows update.
Water flows down the stream
Reply 2 of 3, by Guest
Virus scan says nothing and windows is updated. It is not a virus, my pc isn't even connected to the web...
Reply 3 of 3, by eL_PuSHeR
Still, i doubt this is a DOSBox issue. Run chkdsk and then sfc /scannow. Have your windows CD at hand.
