Motorola Spectra...again
First post, by dunkel
Hi all,
I'm trying to go through this forum in order to program a Motorola Spectra radio. The version of Motorola RSS I am using is R04.05.01 from 01-MAR-95. I seem to notice that if I use the ocbus build for Dosbox 0.65 I manage to communicate with the radio to a much better extent than with any other patch or release I could find here. I actually managed to have the communication test report back "Radio Communications OK". Attached is my config file. I was wondering if anyone managed to find any solution to have this software work with dosbox or at the very least if I could have the "ocbus" patch file (for now I only have the compiled version) so that I could recompile my own version and hopefully debug what is going on with the serial port.
Thank you!
Reply 1 of 2, by gdjacobs
I wouldn't use DOSBOX for this purpose. Have a look at some of the virtualization solutions to see which allow COM port passthrough.
Reply 2 of 2, by dunkel
Do you know if the patch that introduced ocbus is available somewhere? I would prefer compiling this the option enabled and going on my own if possible.
