First post, by Somewhat Damaged
I am running Mac OS X 10.2.8
I was wondering why the games seem to go so slow. I am absolutely THRILLED that I can run my old favorites -- Leisure Suit Larry, King's Quest, Legend of Kyrandia, Afterlife, Ultima: Underworld 2, etc. -- but they just seem to move SO SLOW.
The best speed seems to be at "2500 cycles."
I have an iBook with 500mhz and 128mb of ram...
I know, my computer sucks, but I was wondering if it is too slow to emulate/run DosBox? 😵
thanks
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
i think 2500 is even to high for your machine. (2500 is the default)
The other endian stuff is taking quite some resources.
try setting frameskip to 2
and try again with ctrl-f12 to speed dosbox up
Water flows down the stream
Reply 2 of 7, by Somewhat Damaged
O.K I am ditching the "front-end" program that I am using, and going to try just running it straight out of Terminal.
Thank you so much for the quick reply!
I will use F-12, as well as the frameskip option.
I would have read a "README" file, but it doesn't seem to come with the OS X version of the program. 😵
I NEVER thought I'd be able to run Ultima Underworld 2 on my computer... this is an amazing day. =:-) Thanks again! I'll let you know how it works... Now, if I could just turn off EMS... It's O.K, I'll find that configfile SOMEWHERE! 😉
Reply 4 of 7, by Somewhat Damaged
I'm such a newbie... I can't even figure out how to OPEN dosbox through my terminal.. I tried "dosbox" and "./dosbox" ... Like I said, no idea what I'm doing. 😒
Anyway, I was able to open it with an OS X program called "dOSboX Launcher," but unfortunately it just runs TOO SLOW.
My computer is humiliating.. 500 mhz... *sob* Oh well, I can *kinda* see the opening screen to Ultima UW2 and LSL1, but I couldn't dream of being able to move around without complete lag and going crazy because of the music speed. Frameskip 10 is better than nothing, I guess.
Time to get a new computer? 😒
Reply 5 of 7, by Guest
Still too slow, but at least you gave me the README link.. Thanks a bunch.
Reply 6 of 7, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Well, 500 Mhz is really too slow for Ultima Underworld 2 in DOSBOX. Probably only new computer would help here (or buying an old PC and running it natively).
Mirek
Reply 7 of 7, by Somewhat Damaged
Thanks for the help, guys. 😀
It's nice to know that this program exists, even though my computer is too slow to run it. 😜
I will keep my eyes open for future releases, until I eventually get a new computer... 😢
