Geforce3 Ti 500 vs Geforce 6200
First post, by candle_86
So I have my Ti 500 card it works well but I was given an AGP Geforce 6200 by someone and am wondering if i should swap.
So Geforce3
240/500, 4 pixel pipelines, 1 vertex shader, 64mb Ram, 128bit, 8 TMU's
Geforce 6200
350/400 4 pixel pipelines, 3 vertex shaders, 256mb Ram, 64bit, 4 TMU's
OVerall which one do yall think I should use, would the 6200 be noticable faster
Reply 2 of 96, by clueless1
That's why we benchmark. 😀 Have fun testing it, record lots of results with both cards, then you can make a better choice than any of us ever could. Best of all, you can share the bench #s here and we can all ogle them.
Reply 3 of 96, by Darkman
if your goal is to play Win9x or early Win2k/XP games, the GF3 is the better option , especially in terms of compatibility (Splinter Cell for instance will display its shadows correctly on a GF3 , but not on a GF6200).
later XP games are not going to be fun with either, so I guess the final answer is probably the GF3.
Reply 5 of 96, by sunaiac
MrMateczko wrote:
Any 64bit GPU, no matter how new it is, is going to be abysmal.
That doesn't make sense if we don't know what kind of RAM it is and the effective frequency of said RAM.
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 7 of 96, by Tertz
Keep the Ti installed. Great 98SE compatibility, and no driver/game problems.
Is any data about worse compatibility of GF4 TI compared to GF3 in 9x and DOS?
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 8 of 96, by sgt76
They're pretty similar and whatever a GF3 can do, a GF4 can too, only better. Though a GF3 Ti 500 is nearly the same performance wise as a Ti 4200, so there's not much point in changing it out.
BTW, the 64bit 6200 sucks hard, not as compatible for Win98 gaming plus it's much slower in DX7/8 compared with the GF3.
Reply 10 of 96, by Skyscraper
candle_86 wrote:
I'm just gonna leave my GF3 in the computer unless i come across an FX5950 Ultra
Also consider the FX5900 Ultra, it can use slightly older drivers and can often be overclocked to the FX5950 clocks.
Reply 11 of 96, by Tertz
To have FX as main card on something intended also for DOS needs additional checking befor buying.
FX cards may don't work with VBE refresh utilities in DOS like Unirefresh or VBEHz. It's problem in case you'll want to use SVGA games in DOS on CRT as you'll get 60 Hz only. Some cards work, others on same chip - don't. Sometimes it's possible to get bios from other FX card wich handles refresh ok, but there is no guarantee you'll find such or don't get other issues from alien bios.
Yamaha YMF7x4 Guide
Reply 12 of 96, by PhilsComputerLab
Ti 500 is actually not that easy to find. It's a high end card, often they perform very well, even compared to much newer budget cards.
YouTube, Facebook, Website
Reply 13 of 96, by AzzKickr
I'm in a similar situation. Machine I'm currently typing this from is running a Ti 500, yet would like to have an FX59xx too. Maybe even dual boot with a different setup for each card but sharing the rest of the machine ...
Heresy grows from idleness ...
Reply 14 of 96, by candle_86
oh I know its not easy to find, but there also isn't a big demand for them either, because the Geforce4 does the exact same stuff and has identical support but is faster.
Reply 15 of 96, by AzzKickr
I just ran 3DMark2001 on mine with an awkwardly low score; only 6300 marks. So I'll have to start over with my drivers setup and look into the CPU throttling because I noticed it's running strangely hot ...
Reply 16 of 96, by Skyscraper
With a Nforce 2 system you should get more points but the K7 can not throttle as far as I know.
Here is my Universal AGP test system running a Geforce 3 ti200 @ close to ti500 clocks. Windows 98SE.
Reply 17 of 96, by candle_86
Here is my 3dmark01 run on a Ti 500 under Windows ME
XP 2800
512mb Ram
ABIT NF7-S2G
165.36 KiB
Reply 19 of 96, by candle_86
AzzKickr wrote:
I already found the problem: card was dying. After that benchmark, I turned off the system. Card is now dead sadly 🙁
Well I'd send you mine but I need a replacement first 🤣
