First post, by DracoNihil
My CD is rather scratched, could anybody supply me the SHA1 sums of these retail disc files? Thanks.
85d6ffca86b3458b9349e4ece4615bf825baf7e9  chaos.hog
20cf5157d021e456551478d40fa9cdea725c2a21 chaos.msn
d00b712206e84f6cbd874e271aa4d7ee7c2750e2 descent.hog
24d24e69f15d054774f40d0882c0d4a439fea26c descent.pig
Super paranoid about this, here's some SHA512 hashes:
3efa1cb1edb8a2da4a3f10df9b55af116902309a175e41fd17d3ef8608357cdf2617c64ee32e1919bf6275bfbdcd89ef0723b7afd435142e1229b39e538db84f  chaos.hog
864344def2fa9dfa9feab4948ca32225b318b5ce72969978fd27918dc2f04f67213e246f075f04fe0378172aae184fe211d199cbca15ae04af02fe8c0939e3f5 chaos.msn
218e0fd3097bf187dfc0b2b3b960da1718282da0a44abaa82bb433640f12b0dd55230fe06dadc1f3123670c39c92e785a12b9a7fc312eafe1e2c4d00a0f2d4a0 descent.hog
72986c1838d4d3ac74c071c109e8f85dd5a80faa43406b060769d74e2d84f91530fae2413ea57b69a7f24341fe3b488f02789844158461034513e01d3b5560a6 descent.pig
― Κυνικός Δράκων
Reply 1 of 10, by bjt
Compared to my UK budget re-release CD, they look fine.
// File Checksum Integrity Verifier version 2.05.
85d6ffca86b3458b9349e4ece4615bf825baf7e9 temp\CHAOS.HOG
20cf5157d021e456551478d40fa9cdea725c2a21 temp\CHAOS.MSN
d00b712206e84f6cbd874e271aa4d7ee7c2750e2 temp\DESCENT.HOG
24d24e69f15d054774f40d0882c0d4a439fea26c temp\DESCENT.PIG
If the data track is Mode 1, and you don't get any read errors copying the files, I believe they're nearly 100% guaranteed to be OK due to the CRC checks.
Reply 2 of 10, by DracoNihil
Yeah I think it is. It's also shocking this CD is just 17 MB total size. What a waste of a CD-ROM.
EDIT: My files seemed to patch okay with the patch provided by DXX-ReBirth. Thank you for the reply!
― Κυνικός Δράκων
Reply 3 of 10, by xjas
Don't forget the game originally shipped on 6(?) floppies. 😀 I'm wondering where the extra ~8MB on your CD came from!
I wish they'd included the music remixes by Allistair Brimble from the Playstation version on the DOS D1 CD ... but if you're running Rebirth you can download them and use them in-game. Highly recommended.
Reply 4 of 10, by DracoNihil
I'm using the OPL3 recordings for music.
Also there really isn't much on the disc, there is a .PCX file of a photograph of the dev team though and a few other miscellaneous files that I'm not sure of. The default high score "Words of Wisdom" advertises a "CD Enhanced Version Coming Soon!"... I guess this never happened?
― Κυνικός Δράκων
Reply 5 of 10, by leileilol
Descent II happened. If there's any CD enhanced Descent version it's the Mac and PlayStation releases.
long live PCem
FUCK "AI"
Reply 6 of 10, by Gemini000
Dunno about the PlayStation release, but OH YES, the Mac version of the original Descent blows the DOS version out of the water! :O
The Mac version has remixed CD Audio music of several of the original MIDI tunes, many (though not all) of which sound awesome, the graphics are updated for high resolution and tend to run better than the high-res modes in the original Descent, not to mention there's a high-res cockpit to go with it, which either the Descent 2 cockpit served as the template for or was based off of... I think the only drawback is that the system requirements are technically steeper than the original Descent, seeing as the Macs don't have low resolution graphics modes, so instead, if you have a lesser-powered Mac there's a "Pixel Doubling" mode for the rendering, which is faster than the normal rendering for sure but not nearly as fast as low-res on a DOS machine. :B
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
Reply 7 of 10, by MrFlibble
For some reason I thought that the CD Audio tracks were included with the DOS CD version as well...
As for the high-res version, at least D1X-Rebirth supports Mac game data, although some stuff like sound does not work for whatever reason. I wonder if the sound effects are of higher quality in the Mac version?
DOS Games Archive | Free open source games | RGB Classic Games
Reply 8 of 10, by DracoNihil
Assuming I don't find my backed up installed copy of Descent 2 I might request the SHA1's of Descent 2 and Vertigo Series files to compare against my scratched CD.
― Κυνικός Δράκων
Reply 9 of 10, by Gemini000
Nope. :(
The last patch for the DOS version of Descent added high resolution support, but without any special cockpits or anything, and it didn't support VESA 2.0 and was poorly optimized so it performed much worse than the high resolution support in Descent 2. :P
Reply 10 of 10, by dr_st
It was probably compressed on the floppies.
