SuSE 9.0 RPMS
First post, by Vardamir
Here you can find an RPM and a source RPM for Dosbox 0.61 for SuSE 9.0:
http://sweb.uky.edu/~bebark2/dosbox-0.61-SuSE9.0.i686.rpm
http://sweb.uky.edu/~bebark2/dosbox-0.61-SuSE9.0.src.rpm
It's fine with me if you decide o link them on the main dosbox page.
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
Thank you.
I will add them this week
Water flows down the stream
Reply 2 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
added them
(maybe it would be nicer you put them both in a seperate directory and that I could link to the directory. (as it takes now 2 links)
Reply 3 of 3, by Vardamir
I don't think I can, as I have no control over apache on this server 🙁 The only other thing i could do is put them on a local server running on my DSL connection ... you are welcome to host them yourself of course if you have the room and such.
The src.rpm isn't all that important to most people probably so you can probably just remove that.
