First post, by bytesaber
Voodoo2 listing for two 12MB cards. Noticed they don't have chips on the back side. Is it possible they are only 8MB cards? I'm not sure how to test for 12MB. Do I care about 100MHz memory speed? Thoughts?
332.63 KiB
388.16 KiB
480.12 KiB
Reply 2 of 15, by Munx
I assume these are from Russia?
I have a pair just like these and yes, they are 12MB.
My builds!
The Underdog - The budget K6
Reply 4 of 15, by havli
Yes, this is one of the few single-sided V2 12MB.
btw - two upper chips (BE) in theory should support up to 16MB each. Did anyone try to solder the extra memory on the back side? 😀 CK is already maxed out at 4MB.
Reply 6 of 15, by havli
It should be 36MB in total, yes. But only 16MB of effective texture memory - I believe textures are duplicated. Just like Voodoo5 or any modern dual GPU videocard for that matter.
Reply 7 of 15, by bytesaber
Yep!
anthony wrote:
With 12 chips there is only possible configs 6 or 12 mb. 6 mb is not exists so it 12 mb
Very helpful to know.
Thanks for the info everyone
Reply 9 of 15, by nforce4max
Yep the TMU can go up to 16 mb each on the V2, you can do the same to V1 era cards for extra memory and there is a guide out there.
Reply 10 of 15, by bytesaber
Do games automagically make use of the extra memory? I can solder / desolder chips onto such things. If I "want" to however... well I'm not sure 😀
Reply 11 of 15, by bytesaber
I have two of the same cards pictured above. Here is a screenshot from my system. Is this indicating a problem?
8MB "total" ?
32.25 KiB
Reply 12 of 15, by Skyscraper
8MB "total" ?
That is normal, a 12 MB card has 4MB framebuffer + 8MB texture memory.
Reply 13 of 15, by Gamecollector
Yes, something is wrong. It must be 8 MB + 16 MB.
By the way - fix the info panel with this solution.
P.S. Strange, why your panel shows fxmemmap.vxd but uses WinXp riched20.dll? What are your OS and Voodoo2 driver version?
Reply 14 of 15, by bytesaber
I am using Win98SE
Using version 3.03 from http://www.falconfly.de/voodoo2.htm
I am manually pointing the discovered devices to the drivers, by clicking on 'update driver' and browsing to a directory containing the above extracted files. In my case, just a folder on my desktop.
Last I updated the control panel by overwriting 3dfxv2ps.dll with the first link from http://www.falconfly.de/tools.htm
Can you provide a more appropriate method of installing?
I will try the fix you posted too!
Reply 15 of 15, by Gamecollector
Well, this fix was for WinXp. The panel is ok in WinME for me...
But it looks like even Win9x can have the wrong riched20.dll (KernelEx was installed?) so - use it. The fix just changes riched20.dll link to riched21.dll in 3dfxv2ps.dll so you can use the vanilla WinME file (renamed) and not affect another programs.
