First post, by adalbert
I am trying to run GTA3 on Presario 1800 with 800MHz P3 and Ati Rage Pro 128 (mobility) with 8MB video ram. The game requires 12MB. I know the performance would be probably very bad, but is there a way to either trick the game or operating system (Win 98) to think that there is more memory, so the game will get a chance to start?
The best option would be to solder new memory chips but that would be risky ;p
Reply 2 of 8, by adalbert
Thanks, apparently it needs NT-based Windows (it says ntdll.dll is missing, and doesn't work even with KernelEX), i will install XP or 2000 and check that.
By the way that laptop has 1080pts in 3dmark2001 (1024x768x16) and 1530pts in 640x480x16 so maybe it wouldn't be a total slideshow.
Reply 3 of 8, by adalbert
Update: And it works! In Win XP, but maybe I can make it work in 98 somehow too. I used fresh XP installation with built-in graphic drives. The game is almost playable with only 8MB VRAM which is pretty suprising, as this is only Rage 128 in 2000 laptop computer... I hope there are some free soldering pads so I can solder another 8MB, or else I will look for the mainboard with 16mb (it exists), so even more games will probably work.
Here's the video of gameplay:
https://drive.google.com/file/d/0B2rbHIj6SMlF … iew?usp=sharing
Reply 5 of 8, by teleguy
I made a patch that should remove the memory check. It's based on GTA 3 v1.1, not sure if it works with 1.0.
    GTA3 vram patch.exe
    5.58 KiB
    208 downloads
Reply 6 of 8, by adalbert
Thanks, thats great, it works! 😁
I am now trying to use some other patch in order to make game looking more ugly but faster. I tried running game with 3Danalyzer forcing textures to be 32x32 and it is almost smooth 😜 Regular game works almost fine with top-down camera mode, performance is like with GTA1 on P1 100MHz. Of course i'm trying all of this just for fun 😜
Reply 8 of 8, by adalbert
Well, I could try using GTA VC, but I assume that similar patch would be needed then 😜
Update:
All right, I (probably) managed to do it by myself!
I compared patched and unpatched file and I noticed that only one bit needs to be changed.
Then I edited the gta-vc.exe file and changed:
00 00 00 c0 00 59 59 73
to
00 00 00 c0 00 59 59 eb
same section existed in GTA3.exe.
Modified file still works on my modern PC so I didn't break anything, I am copying the game to the laptop so I can check if it really disabled the memory check 😉
//update2: confirmed, it works 😉 and it is totally playable! Playing with lowest settings (640x480x16) gives 15-20FPS on that 8MB Rage 128. Sure, it's not perfect, but I'm sure that back in 2002 an owner of this 1999 laptop would be happy to see it running GTA:VC. ~35fps on the beach, so forcing lower draw distance or making another modifications would improve the gameplay even more.
