First post, by Echtzeit
Salutations!
I have been trying to fix a problem for the last days and good old search engines have been leading me to this lovely forum many times. Sadly, my exact problem was never discussed.
I got an Omnibook 600ct here with a ESS688 and I'm trying to enable digital sound FX in MS-DOS 6.22. It has never been mentioned before that they wouldn't work, but for some reason they don't work for me or at least behave very strangely. Here is the list of things I have figured out so far.
- Music through OPL3 is working in almost every game when selecting Soundblaster Pro, as was suggested many times
- there are a ton of different esscfg.exe out there, but the one that seems to be the right one for my card only lets me change IRQ and DMA (which looks to be right, according to different sources), but it doesn't matter what combination I try, none worked so far
- sound effects are working in almost no game I've tried (with a few exceptions)
+ Wing Commander 1 - well, at least you can hear the shots, those are digital, right? (in WC2 the speech is not working)
+ the game Lollypop only lets you pick AdLib as card, but effects are working (jumping sounds etc.)
+ SimAnt has sounds working (digging etc.)
- some setup routines give you a hint of might be wrong, here are a few examples:
+ the setup from Dark Forces (iMuse) can't auto detect my card, but when I enter the details manually, music plays fine, sound doesn't (the bar starts to move, then aborts pretty quickly)
+ the game Oldtimer has a setup called idMAS and if I try to start it after putting in my details, it tells me that: "The soundhardware for VOICE uses a DMA channel that doesn't respond". Huh, never heard that before. What does it mean, not respond? The setup pre-selects the correct channels my card is supposed to be at... Again, tried all of them.
- Fate of Atlantis and Civilization won't start at all, all I get is a black screen
- last night I had the idea that maybe the card is plug & play and maybe it would work if I installed it in Windows 98, after trying out a couple of different drivers I found one that works in Windows and let's me play sounds AND MIDI (all the others would crash my system, play no sound or only play MIDI), but this sadly changes nothing for DOS games, they still behave the same way as in pure DOS
So, after all this testing, I actually don't have a clue what hell is going on. Is the card broken or supposed to behave that way? ANY hint at all is highly appreciated. Maybe you guys know a few other games with good setup routines that can be used for troubleshooting or something like that? Is there an actual driver for this card to use for DOS? So many questions... (sorry!)
Reply 1 of 13, by Echtzeit
Small correction:
- when using Windows 98 with the correct driver, now iMuse (from Dark Forces setup) detects the card correctly during auto detect and I can play digitised sound, but the sounds don't come out very clean, there's always a bit of "stuttering" going on (in Windows the sound is very good)
- same for Civilization, no more black screen, it starts up normally (Fate of Atlantis doesn't though)
- but not all games are working like this, these are the only ones I've found working so far that didn't previously work in pure DOS
Reply 2 of 13, by Skyscraper
If this is your card then perhaps it dosn't fully work in DOS, the driver has Plug and Play and "no DMA" in it's name. Perhaps this was the driver package you got sort of working in Windows 98?
Hewlett Packard (HP) ESS ES688 Plug and Play AudioDrive (no DMA) Free Driver Download
http://www.driverguide.com/driver/detail.php?driverid=32301
Reply 3 of 13, by Echtzeit
Yeah, that's the one. If I use ANY other driver (have found four more so far), the system will stall at some point. It's really strange though (even though sounds DO play), is this some special form of the chip? No one has ever mentioned that this card is not fully working in DOS.
Reply 4 of 13, by Skyscraper
Echtzeit wrote:
Yeah, that's the one. If I use ANY other driver (have found four more so far), the system will stall at some point. It's really strange though, is this some special form of the chip? No one has ever mentioned that this card is not fully working in DOS.
ISA DMA is needed for the digital audio in real DOS (or in some cases emulated ISA DMA). TDMA and DDMA were some DMA modes used by the ESS Solo PCI card but I do not know how your ESS Audio Drive Plug and Play is connected in your Omnibook. Perhaps it's worth taking a look at the DOS utilitys for the ESS Solo.
This thread has some information about TDMA and DDMA.
PCI sound cards and Chipsets from various manufacturers...
Lots of drivers can be found here.
http://www.soundcard-drivers.com/companies/382.htm
Reply 5 of 13, by Echtzeit
Skyscraper wrote:
ISA DMA is needed for the digital audio in real DOS (or in some cases emulated ISA DMA). TDMA and DDMA were some DMA modes used […]
Thanks for the tip with the Solo, I will look into that. But can you actually download something from that page? I can't, my virus program goes apeshit and then I can only download some suspicious exe-files (which don't look anywhere near like the drivers).
Reply 6 of 13, by Skyscraper
Perhaps it's a honey trap but then you can at least search for the files using the file names on that site.
Most driver sites makes you jump through rings of fire before you get the drivers.
Reply 7 of 13, by Stiletto
soundcard-drivers.com is pretty clearly related to driverguide, so if you can find it there you can find it on driverguide, usually with the same file ID number they use.
do the Fandango!" - Queen
Stiletto
Reply 8 of 13, by Echtzeit
So, that program for the Solo didn't really work, but I discovered an interesting piece of information.
Settlers 2 Gold has a setup program from Miles Audio (1995). It SPECIFICALLY lists the ESS688 as an option for digital sound!
- under pure DOS auto detection for this card FAILS, as does the one for Soundblaster Pro
- in Windows 98 auto detection for the ESS688 FAILS (again), but works for the Soundblaster Pro
Pretty strange, huh? So, in conclusion (at least the way I see it), the soundcard build into the laptop is some strange variation of the card and is (so far) pretty useless for DOS games, IF you want digitized sound. I'd still like to understand what is going on, so any other information anyone might have is appreciated.
(Oh, and Commander Keen 5 has sound effects in DOS, are those digital or FM synthesis?)
Reply 9 of 13, by Rawit
I have an Omnibook 600CT, but the soundcard implementation is DMA-less, like PCMCIA soundcards. In short, there is no way to get PCM under pure DOS, Windows 9X is your best bet for effects in DOS games. Some games don't require DMA, like Prince of Persia, and will give you sound effects under DOS.
YouTube
Reply 10 of 13, by DMJC
I just bought one of these laptops yesterday. I have yet to test it but I found this information on the Toshiba website regarding DOS compatibility:
Subject: ESS Sound System compatibility with Sound Blaster Pro DOS based
software/games requiring Sound Blaster or Sound Blaster Pro compatible
sound cards. The following Toshiba units shipped with the ESS 688 Sound
System chip which is compatible with Creative Labs Sound Blaster chipset:
Satellite Pro 400CS/CDT
Satellite Pro 410CS/CDT
Portege 610CT
Tecra 700CT
During installation and setup, various games may have difficulty detecting
SoundBlaster Pro or ANY sound card at all.
Solution: Move Sound I/O Address in TSETUP from 220 (default) to 240
and IRQ to 10 (default). DMA channel should be set to 1 (default).
In the autoexec.bat file add the following:
set blaster=a240 i10 d1
set midi=synth:1 map:e
Reply 11 of 13, by CkRtech
Nothing quite says “good luck in DOS! Lol!!” like a sound card defaulting to IRQ 10. 5 or 7 would be better.
Displaced Gamers (YouTube) - DOS Gaming Aspect Ratio - 320x200 || The History of 240p || Dithering on the Sega Genesis with Composite Video
Reply 12 of 13, by LSS10999
Yeah... Apparenly some games may refuse to run if the sound card is not on IRQ 5 or 7. I had a time when a semi-PnP Sound Blaster 16 (CT2290) of mine defaulted itself to IRQ 10 and DMA3, and games like Wolfenstein 3-D refused to run (just hangs there). For that sound card, I was able to fix it by using Creative's DIAGNOSE to assign IRQ5 and DMA1 to it.
Even for ISA PnP audio devices you're supposed to ensure the card is assigned to the common resources (I/O 220, IRQ 5 and DMA1). Utilities provided by manufacturers (such as ESS) should help you with that.
The difficulty for certain games to detect Sound Blaster actually lies in the fact that the BLASTER environment variable is often not preconfigured and you need to set this manually. This is true for many Apogee/3D Realms games and those game's help manuals include instructions to set this variable, if you read them thoroughly.
EDIT: Many games expect the BLASTER environment variable be set, yet it can also be very easily overlooked. Without BLASTER many games can only properly configure music playback as FM synth usually requires no configuration. When I was still little, with a very old PC equipped with ESS 688 (non-PnP), I'd been struggling to get digitized audio on many games as they crapped out because BLASTER environment variable was not set, and at that time, I did not know how to set the variable until I found the "proper" way to define the variable inside a game manual of an Apogee's game.
Reply 13 of 13, by kirikl
What is the summary. No Sound until Windows 95?
I have sound in ST-Tracker and Games like Jill. I tried everything , even flash old BIOS for W31... It's even worse, no sound in 95 then 😀
So back to 95 (4.01) BIOS, I have ESS1688 though, not 688.
ESSCFG with parameters like 220 I5 D0 - hanging the machine... 🙁
DOS prompt from win 95 works good for those games which are not hungry for memory. I guess that's only option?
Adlib like in DOS
SB PRO like in Win95, including DOS prompt.
Isn't it?
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
Sony Vaio PCG-SRX99 / PCG-505TR / C1 Picturebook
Compaq LTE Elite 4/75CXL / LTE 5000
Toshiba T1100+ / T3100e/40 / T3200SXC
Tandy 1400 LT / 1000HX
PB G4 1.33 / G3 300
iBook Cl 300
