Drive not mounting
First post, by Nathan1100
I'm having an issue, it looks like this:
Z:\>mount c c:\Games
Drive C is mounted as local directory c:\Games
Z:\>cd AUTOPLAY
You are still on drive Z:, change to a mounted drive with C: .
How do I fix this?
Reply 1 of 5, by mrau
like that
Reply 2 of 5, by Nathan1100
mrau wrote:
like that
But as it showed above I believe I already mounted the C drive
Nathan1100 wrote:
I'm having an issue, it looks like this: Z:\>mount c c:\Games Drive C is mounted as local directory c:\Games Z:\>cd AUTOPLAY You […]
Z:\>cd AUTOPLAY
How do I fix this?
"Z:\>mount c c:\Games
Drive C is mounted as local directory c:\Games"
Reply 4 of 5, by Nathan1100
collector wrote:
After mounting you drive you have to then change to that drive. It is just like in real DOS
c:
Then press enter.
Thank you, I did not know that I had to do that. I actually haven't used an actual DOS computer so i'm unfamiliar of some of the commands used with those systems.
