First post, by PoulpSquad
- Member
Hello
Is there a way to display the Control ROM revision on a Roland SC-55 unit?
Thank you for your help!
Hello
Put the unit in standby mode (orange led is lit) and press simultaneously: both "Instrument" and both "Midi Ch" buttons .
If you do it correctly the screen will come up and display the control rom version. It might take some tries but you'll get it right, you really need to press all 4 buttons at the same time.
Thank you so much for your help!
Thank you. I was able to confirm my SC-55 firmware with this exact method.
Thanks, confirmed my sc-55 version is 1.21
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: Shuttle SK41G/AthlonXP 2200+ 1.8GHz/V3 3000/SuperQuad Digital/MU90/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
