First post, by PcBytes
- l33t
I'm back with another Pentium 4 rig,this time on a retro case quite common back in the days around here (now they're rare,almost as rare as hens teeth),the JNC RJA52. It's a white Deer case,just so you know.
Interesting enough,this model is still sold (albeit in colour combinations,such as blue with white) under the "JAR Computers" brand in Moldova (possibly,since some sites end in .md) and around some parts of Russia. That's what I know,it may be wrong though.
Anyways,here are the specs. This was originally a Sempron 2200+ system,based on the PCChips M825G,which actually isn't that bad.
Specs:
PSU:JNC LC-B300ATX - it's a robust one with PFC that I got for cheap. Someone did a awesome job at recapping,since I only see 2 Teapos and lots of Rubycons and Panasonics. Sadly it has a EI-33 transformer,but I got my eyes on a Premier LC-B400ATX for sale that has a 35 transformer so I can do some real nice mods,assuming that the platforms match.
Motherboard: Gigabyte GA-8IPE1000 - another good motherboard. Came with a CPU that was dead. (no POST with that,another one works)
CPU: Pentium 4 2.8GHz Northwood Socket 478 - this one is the CPU that works. The dead one is a SL6DV Pentium 4 2.4GHz,also a Northwood.
RAM:2x 512MB DDR400 PC3200
GPU:Geforce FX5500 128MB - would have used a Radeon HD3450 but I guess the FX5500 is more than enough.
HDD: Maxtor 6E040L0 40GB - came with the PC. Had some corrupted XP install I don't care about.
ODD: Pioneer DVD-117 DVD-ROM and ASUS CD-RW drive.
NIC: RTL8139C - mobo doesn't have NIC integrated - supposed to be a Marvel Yukon
FDD:Alpine FDD 3.5"
OS: Longhorn Build 4074 - I plan on installing either 4074R2 or a i386 repack that uses the old XP setup routine (and takes MUCH less than R2)
EDIT:Pics attached.
