deactivate mouse
First post, by Freight
Hi,
i use dosbox under linux. it works very fine! however i have to deactivate the mouse, so a programm wont find it. Is this possible? How?
Thanks.
Yours Freight
Reply 1 of 3, by Harekiet
Rank DOSBox Author
DOSBox Author
Hmm you'd have to write a little program to overwrite the int 33h mouse interrupt or edit the source. And before you ask, no there will not be a config option.
Reply 2 of 3, by Guest
Thanks!
I know its a little bit strange. But i have to deactivate it. Dosbox works very fine, but ma app...
So you may give me a hint how to write this programm?
Thanks again
Reply 3 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
uhm find a crash course on dosprogramming
more specificly find some help on assembly and intterupt vectors 😀
As you are under linux I advise you to change the source of dosbox 😀
Look at dosbox.cpp (in dosbox/src/) and look for
something like add_initfunction(Mouse_INIT)
just comment that line and the mouse is disabled.
more specificly
secprop->AddInitFunction(&MOUSE_Init);
that line.
And recompile of course.
Water flows down the stream
