First post, by Skyscraper
I have found that it's a tantalum capacitor shorting, in practice bridging [EDIT] GND [/EDIT] and -12V. No wonder the XT and AT power supplies got overloaded instantly and wouldn't power on.
I'm not going to ask for a return or refund from the seller as this time bomb could have went off when I powered on my XT clone testing the card. It's a bit irritating that a leg on the "transistor" I first thought was shorting broke off when I bended it slightly, the transistor got beatup by the card beeing shipped in an envelope and the leg broke off all too easily but its a 0.2 euro componant so it's not worth fighting over.
I need a good suggestion what capacitor I should replace this tantalum capacitor with?
The attachment Shorted tantalum capacitor..JPG is no longer available
The "transistor" I broke is a is in fact an "adjustable precision shunt regulator TL431C". I guess I can replace this with either a new one or another TL431x (the last letter is just operating temprature range) from a broken card but (the latter will perhaps be a problem as the middle leg needs to be long enough). The middle leg goes by one of the outer legs to reach solder pad "3". Without the plastic beed in the correct position it looked like the legs were shorting and when I tried to get the plastic beed in the correct position the middle leg broke off all too easily. The picture is taken after I adjusted the beat up "transistors" position but before I moved the beed and broke off the leg.
The attachment Now broken transistor.JPG is no longer available
Reply 1 of 11, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
> bridging +5V and -12V
I don't think so. These capacitors are GND relative. If you find both -12V and +5V shorted to GND then probably two capacitors are shorted.
Did you unsolder the capacitor to test? If not, it can still be anything else on the card that is shorting as most components are connected to 5V and GND in parallel.
You can test the card with such capacitor removed. The value of this particular one is 10µF/16V.
TL431 from another card will be fine. You can also often find them in switching power supplies near the optocoupler. On the VGA it is used as current source for the video DAC.
1+1=10
Reply 2 of 11, by Skyscraper
h-a-l-9000 wrote:
> bridging +5V and -12V I don't think so. These capacitors are GND relative. If you find both -12V and +5V shorted to GND then p […]
I have not desolderd the capacitor yet. Can I replace it with an electrolytic capacitor with the same values and if so does it need to be low ESR?
You are correct -12 is only shorted to ground and not to +5v, I just rechecked. From B07 to B01 (or B10 also GND and where the cap goes) my multimeter shows 0.5 ohm and measured over this resistor (still on the card) it also shows 0.5 ohm while B01 to B03 shows no connection. I will desolder it now to make sure it's this one.
I must have confused measuring resistance between B07 (-12V) and B01 (GND) vs B03 (+5V). I only measured on the fingers quickly to see if there indeed were any shorts at all then I moved on to checking the caps so with luck it's only the cap and no other shorts.
Reply 3 of 11, by Skyscraper
Success, no more short between -12V and GND! 😀
And the cap is still shorted when removed from the board.
This was a bit hard to do with one hand for the camera!
The attachment No short.JPG is no longer available
This was extremly hard to do with one hand for the camera, some tape to hold the cap in place was needed! The multimater read 0.5 to 0.6 ohm when i held it securly with both hands but 0.6 - 0.7 ohm with one unsteady hand.
The attachment Still short.JPG is no longer available
Reply 4 of 11, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Electrolytic is no problem (aside from aesthetics).
Secret hint: GND is on the slot cover - easier to stick the prober there.
1+1=10
Reply 5 of 11, by Skyscraper
I though I had a broken OTI037C with both a non shorted 10µF/16V tantalum capacitor and the correct TL431C shunt regulator. As a bonus the middle lead on the TL431C looked long enough to reach solder pad "3" on the 8bit OCTEK UM587F. I have tested this card in 3 systems with 3 different screens with the same result, the screens shows that they get a signal but the screens remains black with the systems booting as normal.
This is the "broken" OTI037C card, the sought after components are in the upper right corner.
The attachment Seemingly non working OTI037C VGA card.JPG is no longer available
I have two other very similar OTI037C cards and they both work fine with the LCD screens I have tested but I thought I should test this card with a CRT just to make sure as all 3 systems I tested the card in uses LCDs (including the XT clone). I put the card in the XT clone and conneted an old VGA screen I dug out from the mess and sure enough the stupid card works fine, just not with LCDs.
Why did you have to work?
The attachment Why did you have to work.JPG is no longer available
I guess I will have to order a new TL431C shunt regulator when I order capacitors from Mouser or ELFA. I dont want to desolder parts from this card now that I know it works as it looks almost new but this means it will take a while before I can fix the 8bit OCTEK UM587F. I did find a PSU in my scrap pile with bloated caps and a TL431 but it's soldered very snug against the board and the middle lead will not be long enough to reach around to solder pad "3".
I will continue to seach my scrap piles too see if I find any other donor hardware.
Good! I have plenty of small electrolytic caps if I should find a suitable TL431 but not a 10µF/16V tantalum capacitor.
Thanks for the help! 😀
Reply 6 of 11, by orinoko
It almost sounds like the card only worked in the XT machine because the ISA bus would be running at 4.77Mhz, and not something faster like 6Mhz or 8Mhz (or more...). This card quite simply could just be not working due to the faster bus speeds on your other motherboard...
Reply 7 of 11, by Skyscraper
The XT clone ran at 10 MHz and this system was one of the three systems I have already tested this OTI037C card in, a 386 25 MHz and a Slot-1 system beeing the two others. This is one of the cards I got in the scrap lot I posted pictures of in the "Bought these (retro) hardware today" thread a week ago.
You are correct that it wasnt a LCD vs CRT screen thing though as I just retested the card with the LCD I have been using with the XT clone and the combination now works. Things I tried before to see if I could get the card going was to reseat the removable chips and cleaning the fingers but it diddnt seem to help. It seems the card just wanted some attention but scaring it with using it as spare parts was the correct procedure. This is not the first time things start working when I test them the "very last time" before salvaging useful components, it's usually 486 motherboards though.
Reply 8 of 11, by orinoko
Haha yeah this old stuff is always a little bit tempremental.
For example, my IBM PS/2 had a faulty floppy drive until I drove it from Adelaide to Melbourne (around 700Km) and it now just magically works...
Gotta love this stuff. It all has such a quirky character to it.
Reply 9 of 11, by Skyscraper
Well it's hard to complain when stuff magicly fixes it self. 😀
Reply 10 of 11, by orinoko
Yeah! Would like to know why it happened though so it doesn't happen again haha
Reply 11 of 11, by vgeorgiev
Hi Skyscraper,
I have exactly the same vide card. Do you have the settings for the modes ?
Skyscraper wrote on 2016-04-27, 17:42:
