First post, by giomach
giomach
Offline
When using the "name" option on the dosbox command line to specify a program, is it possible to supply a parameter to that program? (When running the program from the normal DOS command line, program parameters follow the program name, separated by spaces.)
A workaround is to create a batch file to hold the program name and parameter, and name the batch file to dosbox, but it would be tidier if it could all be done on the dosbox command.
Thanks for your help.
