First post, by jdgalt
jdgalt
Offline
- Newbie
I'm running Ubuntu Linux 16.04.
After getting the source (which wouldn't compile, see [1]),
I used the command
. $ sudo apt install dosbox
to install it, which appeared to work fine.
But when I start up the program (from ubuntu's menu bar) I get this:
. $ /usr/bin/dosbox -?
. DOSBox version 0.74
. Copyright 2002-2010 DOSBox Team, published under GNU GPL.
. Exit to error: Can't init SDL No available video device
Please fix.
[1] https://www.reddit.com/r/linuxquestions/comme … pile_on_ubuntu/
