First post, by Tempest
- Member
I'm getting back into DOS gaming after a long absence, and I need some help making my config.sys and autoexec.bat. Is there anything I'm missing or should change?
Here's my system:
System: IBM Personal Computer 350 (Pentium 200Mhz)
Graphics: Matrox Millennium MGA (card) or S3 Trio64V+ (built in) - I can use either, current using the Millennium
Sound: Soundblaster Awe32 + Roland MT-32
OS: Windows 98 SE
Other: CD-ROM drive (Lite-On LTR-32123S), 3.5" floppy, 5.25" floppy
Here are my files. I have two autoexec's, one is .bat and one is .dos. I don't know if Windows 98 uses the .dos one for booting into dos mode or if that's a left over from my DOS 6.22 installation.
autoexec.bat
@echo off
set path=C:\windows;C:\windows\command;C:\dos;C:\
prompt $P$G
set temp=C:\temp
set sound=c:\SB16
set blaster=A220 I5 D1 H5 P330 E620 T6
set midi=synth:1 map:E mode:0
C:\sb16\diagnose /s
c:\sb16\mixerset /p /q
lh c:\windows\command\doskey /insert bufsize 1024
C:\sb16\aweutil /s
lh c:\dos\mouse.exe
lh c:\windows\command\mscdex.exe /d:mscd001 /L:E
autoexec.dos
@echo off
prompt $P$G
set temp=C:\temp
set sound=c:\SB16
C:\sb16\diagnose /s
C:\sb16\aweutil /s
lh c:\dos\doskey /insert bufsize 1024
lh c:\dos\mouse.exe
lh c:\dos\mscdex.exe /d:mscd001 /L:E
lh c:\dos\smartdrv.exe
config.sys
lastdrive=z
device=c:\dos\himem.sys
device=c:\dos\emm386 NOEMS
dos=high,umb
buffershigh=30,0
fileshigh=50
devicehigh=c:\dos\ansi.sys
devicehigh=c:\sb16\drv\csp.sys /unit=0 /blaster=a:220
devicehigh=oakcdrom.sys /d:mscd001 /L:E
devicehigh=c:\dos\setver.exe
If I restart in DOS mode it says I have 620K free and the largest free upper memory block is 0K (496 bytes)
if I use DOS through windows 98 it says I have 604K free and the largest free upper memory block is 0K (0 bytes)
If I boot to command prompt only through the Win 98 menu it says I have 619K free and the largest free upper memory block is 7K
--- AtariProtos.com ---
For when excellence and burnished fineries need to gently visit the warmth of your tablery
