First post, by curlyboi
Hi,
so I just opened this account to share a tool I have developed to work with DOSBox nullmodem feature.
It is a dedicated server which will wait for a connection on port of your selection and whenever someone
connects, it will accept it.
It will automatically pair new users by the order of their connection. Example scenario:
- User1 connects
- User2 connects
- System pairs User1 and User2 as if they were directly connected by serial cable
More complex scenario:
- User1 connects
- User2 connects
- System pairs them up
- User1 disconnects
- User3 connects
- Systems pairs User3 with User2
In DOSBox you can have both users type SERIAL1 NULLMODEM SERVER:whatever.com PORT:whatever123
Whatever.com is the address of your TcpLobby server.
You can also supply 2 command line parameters to the exe: local IP and port. If you specify them, listening
will start immediatelly without user intervention.
    TcpLobby.zip
    166.94 KiB
    121 downloads
    TcpLobby source and binary.
