First post, by Ozzuneoj
- l33t
I recently came into possession of several very old IDE drives from the early to mid 90s, and in fact I had a couple laying around for years that I hadn't even plugged in until very recently.
I plan to test the drives, keep some for myself and find homes for the rest of them as fully tested and working drives.
As a tester system I'm using a Dell Dimension 4500S since its a fairly compact system, is super power efficient (for an XP capable system, idling at ~25 watts is decent), has IDE interfaces, and is fast enough (with a 2.4 northwood P4 and 1GB DDR) to run Windows XP and Hard Disk Sentinel Pro.
Something I've run into though is that some drives will spin up and then stop when XP loads, and they cause the whole system to work very slowly. If I boot from a Windows 98 DOS boot floppy the drives do not shut off and in fact are seen by FDISK... but the whole process of loading DOS from the floppy is far slower than normal and FDISK won't proceed past "0%" of verifying drive integrity when creating a primary DOS partition.
I'm not sure if the drives that are doing this are totally bad, if something isn't configured properly or if the motherboard's IDE controllers are simply too new to work with these old drives.
The one I have hooked up right now is a Seagate ST-1144A 130MB which is a 3.5" but is one of the older "thicker" drives and it behaves exactly as described above. I checked the jumper settings and they appear to be correct (master with no slave). Before this one I tested a Quantum ProDrive LPS 52 52MB drive and it worked flawlessly in XP, formatted without problems and has zero bad sectors.
Anyone know if older IDE drives have compatibility issues with newer controllers?
