First post, by keenmaster486
So maybe I'm a dumbo, but I just don't understand this.
Why is it that you can get two processors that are identical in every way, except for the clock speed?
For example, what is the difference between these two:
#1 - 486DX @ 25MHz
#2 - 486DX @ 33MHz
or these two:
#3 - Pentium P54C @ 133MHz
#4 - Pentium P54C @ 166MHz
Why couldn't you just overclock CPU #1 to 33MHz (for example) and have it be identical to CPU #2? [ditto for #3 & #4] There must be something I'm missing here. Are CPUs #2 and #4 made more robustly somehow, in order to handle the higher clock speed?
Somebody please elucidate.
World's foremost 486 enjoyer.
Reply 1 of 5, by PhilsComputerLab
They are just speed binned. Meaning Intel (or whoever the manufacturer is), tested the processor at various speeds. If it handled 200 MHz, it became a 200 MHz chip. If it failed the 200 MHz test, but passed the 166 MHz test, it became a 166 MHz chip.
Sometimes though yields were good and people wanted to buy more 166 MHz chips than 200 MHz chips and then a 200 MHz chip would become a 166 MHz chip and overclockers loved that 😊
Reply 2 of 5, by BloodyCactus
or they were tested and passed using a higher bus multiplier.
Reply 3 of 5, by carlostex
Intel or other manufacturers don't put different dies in a single silicon wafer. Dies are first checked to work and then packaged. After this they probably do the "burn in" tests (not sure if they call it like this) and speed tests. So, as Phil says, they test the CPU's at various speeds and go slower if the chip fails the test.
These days manufacturing processes mature so fast that most chips work perfectly at maximum intended speed for that specific micro-architecture.
We may think that this seems very wasteful, but designing a different die for every single variation is simply not viable economically.
Reply 4 of 5, by clueless1
I wonder at what point they put the multiplier locks in (for locked cpus). Obviously it has to be after the speed tests, but do they decide right away "this is going to be 166Mhz" or do they store it and watch demand, then at the last minute before shipping out to sell, lock it at 166Mhz when they decide they have too much 200Mhz inventory compared to demand.
Reply 5 of 5, by keenmaster486
Aha, this explains things. Thanks! You learn something new every day... 😎
