First post, by clueless1
- l33t
Back in the early 1990s, I had a Packard Bell Legend 386sx-20 with a turbo LED (I can't remember if there was a switch on the case or if it was keyboard controlled). I don't remember much about it. I've seen lots of PCs with turbo buttons over the years, and know WHAT they do. What I'm having a hard time finding out is HOW they do what they do.
In my mind, I imagine that the button is attached to a pair of wires with a jumper on the end, and the jumper plugs into a "turbo" header on the motherboard. Is that part right? Or does it work differently?
I've read that on some PCs, there is no turbo button on the case, rather it is controlled by a button or keystroke combination on the keyboard. How does this function in comparison to the button on the case?
Lastly, what happens when the turbo button is pushed? Does it downclock to a set speed, a user-definable speed, or does it simply disable cpu and motherboard caches? Or does it depend on the system?
