First post, by clueless1
- l33t
I'm starting to think about getting a long workbench/desk so I can have up to 4 PCs set up. The plan is to have two monitors/keyboards with KVMs to switch between the 4 PCs. My requirements are that it is inexpensive (under $200US) but not flimsy. I'm not too picky about it looking fancy, so long as it doesn't look like a cheap fold-up. Not sure if 72" is too long? Seems somewhere around 60" x 24" would be decent dimensions.
Here's a couple I've come across:
https://www.amazon.com/HON-COMPANY-Utility-29 … t/dp/B00AC895M4
But this seems a little pricey for what it is.
and
https://www.amazon.com/Need-Computer-Portable … e/dp/B018G6A6HG
not long enough? 47" seems like it might be cramped, but I will only ever be in front of one monitor/keyboard at a time, so maybe not.
What do you use? Do you have any recommendations?
Thanks.
