First post, by SRQ
I got an ancient 386 laptop. Pretty cool- but I have no power supply for it.
This machine is really cool and I'm willing to spend a bit to use it, but I can't find replacements online- understandably. Does anyone have one and can either figure out what else would work and I can find, or help me modify a different once?
http://i.imgur.com/7VPbpOm.jpg
what even is this, why
Reply 1 of 7, by ncafferkey
I've try to attach a photo of the bottom of the PSU, which has a pin out diagram.
Reply 2 of 7, by SRQ
This helps but damn, I cannot find a single source online to actually get one.
16V though, maybe I can modify something.
Reply 3 of 7, by Ampera
Just get a 16v adapter that's about the same current, and worry about the end later. They sell universal laptop connectors, or if you have one, use a variable bench supply.
Reply 4 of 7, by SRQ
The end is the problem. You see the pinout on that pic? That's what the end looks like. Nothing else I have ever seen has that end.
I can rip apart a power supply and try to kludge something I guess.
Reply 5 of 7, by Ampera
Looks like a DIN connector to me.
Reply 6 of 7, by yawetaG
They sell universal power supplies that come with connector adapters. Whether those come with DIN connectors is anyone's guess, but since most connectors can be bought separately soldering an adapter lead yourself should not exactly be rocket science...
Reply 7 of 7, by ncafferkey
BTW, I had the problem that the rubber "bumper" alongside the latches for the screen was "melting", but I discovered there's just a thin layer of rubber that can be cleaned off to reveal shiny black plastic underneath.
