WtF, Rayman?
First post, by Gamecollector
Have played the first rayman game in the DOSBox (EU version 1.12). "If you have died once on a level - restart it", "get all lives" etc.
There is 1 trouble.
Caves of Scops, "Eat at Joe's", the 3rd map (right after the Firefly one).
When I try to get the 4th cage on this level (must run, jump from the ledge above the exit, glide and grab the ring) - this *censored* limbless hero hits the ring but not grabs it.
The ring can be seen there as the example (6:31 - 6:35).
AAARGHHH!!!
Somebody help!
Unfortunately FRAPS not movies this game on my PC. After I find a proper streaming software - I will add the video of this "surprise".
P.S. Ok, Hypercam 2 and DOSBox in the window mode did the trick.
Reply 2 of 5, by Gamecollector
Jorpho wrote:
So you're running this in DOSBox, right? Are you using any of the fixes discussed in Re: Rayman - speed issues in DOSBox + possible workarounds ?
The speed issue?
You just need to quit in the main menu then load the game again to fix it.
P.S. I have tested "core=normal" and fixed cycles to be sure. Well, no luck.
Reply 3 of 5, by Jorpho
I was thinking that if it's some weird sprite-collision issue, then maybe messing with the video settings will solve the problem.
Reply 4 of 5, by Gamecollector
PCI1 and VESA in settings? I will try this.
Got another idea. IIRC I have the US 1.21 version somewhere...
P.S. Nope. Both ideas are failed. Same glitch.
Reply 5 of 5, by Gamecollector
Have attached the video with this glitch to the 1st post.
