First post, by Paragon
I think it is a country issue.. The thing is, I can't type \ (a backslash)
Anyone else have this problem, and anyone know a workaround?
This might be because I have a danish keyboard, but \ usually works fine in other DOS environments..
Reply 1 of 3, by MabusRaeen
Please be a little bit more specific...
Do you mean you can't type a backslash in DOSbox itself or you can't type a backslash at all (which I would find very hard to believe)
Here's a little work around.
Open DOSBOX.CONF in notepad and look for the [autoexec] part. (it's a the bottom)
Now type
mount c C:\
Unless you're completely unable to type a backslash, this should work.
Alternatively, you could use my front end which allows you to mount with out typing anything. The link is in my profile
Cheers.
Author of D-Fend, a DOSBox frontend.
D-Fend homepage.
http://members.home.nl/mabus
Reply 2 of 3, by Markus
Search the forum, this issue has been asked a hundred times.
You can use the forward slash "/" with mount (mount c c:/someprog)
