First post, by kellogg
I'm having trouble getting Crusader No Remorse and No Regret to work on WinXP with the DOSBOX program. If anyone has any experience getting these games to work please respond and give me instructions on how to get them to work correctly. Thank you for your time.
Reply 1 of 1, by Shade
Edit the dosbox.conf file.
Write the following lines in the [autoexec] section:
"mount c e:\
mount d g:"
Where "e:" is the drive (in windows) where you want to install the game. (the command alocates e: to the c:\ drive letter in dosbox)
And "g:" is the CD drive you install and play from. (it is being allocated to d:\)
You should also set "fullscreen" to true, and cpu cycles to around 5000.
I used dosbox 0.61, and it worked nicely.
