First post, by brassicGamer
Something I'm really interested in is the advance of PC hardware. In particular, what was the first occasion a piece of new technology was introduced. It seems nearly impossible to tell, historically, when things like USB or SDRAM were first introduced in a product. Aside from engineering samples, which are extremely rare and technically 'don't exist', it seems the only way to establish what came first is to have a kind of competition where someone posts up a motherboard they own and says 'this is the first retail motherboard to include USB and see if anyone else comes forward to argue.
I would like to establish such a project and I think you good people would be an amazing resource to call upon. I guess the VCF community might also have something to offer - I'm not really involved there yet.
So does anyone know of an existing project before I reinvent the wheel? If not, allow me to fire the first silo, which is the ECS P5VX-B from 1996. Do you know of an earlier motherboard supporting USB?
http://web.archive.org/web/19961103172425/htt … cts/p5vx-b.html
886.84 KiB
623.12 KiB
Reply 2 of 11, by clueless1
That level of specificity is very ambitious. The other recent project started up here on the best hardware of each year could be considered similar, but maybe easier to achieve? In either case, archives of old magazines will come in handy. 😀 Here's that other thread:
Top hardware by year
and the data collection:
https://docs.google.com/spreadsheets/d/1Bhlr_ … 44jM/edit#gid=0
BTW, really impressive motherboard you show in your photos. Love the USB header next to the AT keyboard connector.
Reply 3 of 11, by stamasd
You may find some info on the Red Hill website http://redhill.net.au/ib.html
It's not organized by any other criterion but years though.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 4 of 11, by brassicGamer
clueless1 wrote:
That level of specificity is very ambitious. The other recent project started up here on the best hardware of each year could b […]
Yeah you're right about this being ambitious (also known as 'pain in the ass ') but I figured if Vlask can catalogue every known graphics chipset then it's worth doing.
I've been keeping an eye on the other thread you mentioned. If it gains momentum it would make a very nice complementary project.
And the board - I've had it a while and only just noticed how nice it is. Everything is white and socketed. Might try to find a COAST module for it. Weirdly though i tried a load of SDRAM in it and none POSTed. Supports up to an MMX 200 but probably supports more unofficially.
Reply 5 of 11, by brassicGamer
dirkmirk wrote:
The intel PR440FX printed manual suggests August 1996 and supports USB.
Nice! We're getting some dates 😀
I will populate a Google Docs spreadsheet with some preliminary data and see where it goes.
Reply 7 of 11, by brassicGamer
I've already done a lot of work on this and will be able to present a work in progress version soon. Most of all, I want all dates to be referenced by some kind of press release or article from the time period. I have already read a lot of information online that is either imprecise (ideally day / month / year. Month / year at the very least) or recycled or just plain wrong. This needs to be historically factual and accurate or it's not worth doing.
Fortunately Google has searchable scans of InfoWorld, PC Mag and ComputerWorld, which give a pretty good impression. Specification documents from the time are hard to find for obvious reasons!
Also thinking about the best way to present this information. I like Vlask's VGA chart because this project is similar (timeline format).
Reply 8 of 11, by brassicGamer
Any chance you could provide a scan / photo of the title page? I have found specs online and it says November. I would like to be able to link a source if possible, thanks.
http://home.icequake.net/~nemesis/pc/support/ … fx/28182902.pdf
Reply 9 of 11, by brassicGamer
Okay so I wanted to share what I've done so far. I used a Google sheet for speed as gathering the data is more important than how it looks at the moment. I have split it into items of hardware (mostly - the history of Overdrive chips is a bit different) and provided significant dates, with a source. In most cases there are links to InfoWorld on Google Books because that's the publication I have used so far. In the future I will have a more diverse list of sources as I find more reference material.
Thoughts?
https://docs.google.com/spreadsheets/d/1NESLd … EVQUa3o/pubhtml
EDIT: I've just noticed that 'notes' attached to cells are not published from Google Sheets, which makes the current format a bit pointless as it appears as a date only, when it should have a summary pop up. I'll work on it.
Reply 10 of 11, by clueless1
There's also Insert Comment and Insert Link options if one of those will work better for you. So far looks amazing! Will check it out in more depth. Thanks for doing this. 😀
Reply 11 of 11, by brassicGamer
Okay I have renamed the project (and thread) and converted the Google Sheet so it's, er, useful. People with big monitors will have more joy. Consider this a 'dev' version. The final product will be much more presentable and pretty as soon as I learn how to make timelines in jQuery or something.
Enjoy this trip through the late 80s and 90s of PC hardware:
https://docs.google.com/spreadsheets/d/1NESLd … 290&single=true
It's not quite yet the level of specificity that I was hoping for (i.e. mapping the first products on the market) but there are some examples of that. Mostly it maps particular standards and how they established themselves in the market. It also maps Intel's monumental fuck-up with the Pentium Overdrive and some other fiascos. All of them Intel's, in fact.
p.s. some of the links are a bit screwy - I need to find a better way to link to a specific page on a Google Book, because presently I can only do it via keywords search. If anyone has any tips I'd appreciate it.
