First post, by oeuvre
Hi all,
Not sure if this exists already but feel free to share your MS-DOS AUTOEXEC.BAT + CONFIG.SYS files here!
From my 486 system...
AUTOEXEC.BAT
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P330 T6
SET MIDI=SYNTH:1 MAP:E
SET CTCM=C:\CTCM
LH C:\SB16\DIAGNOSE /S /W=C:\WINDOWS
LH C:\SB16\MIXERSET /P /Q
LH C:\CTCM\CTCU /S /W=C:\WINDOWS
LH C:\WINDOWS\net start
LH /L:0;1,45456 /S C:\DOS\SMARTDRV.EXE /X
@ECHO OFF
PROMPT $p$g
PATH C:\WINDOWS;C:\DOS
SET TEMP=C:\DOS
SET PATH=%PATH%;C:\CDROM
LH C:\CDROM\SHCDX33F.COM /S /D:MSCD001 /L:D
LH /L:0;1,3328 /S MOUSE
CONFIG.SYS
DEVICE=C:\DOS\HIMEM.SYS /Q /TESTMEM:OFF
DEVICE=C:\DOS\EMM386.EXE RAM AUTO I=B000-B7FF
BUFFERS=40
FILES=50
FCBS=4,0
DOS=HIGH,UMB
LASTDRIVE=G
DEVICE=C:\CTCM\CTCM.EXE
DEVICEHIGH /L:1,40800 =C:\CDROM\VIDE-CDD.SYS /D:MSCD001
DEVICEHIGH /L:1,12048 =C:\DOS\SETVER.EXE
DEVICEHIGH /L:1,4560 =C:\WINDOWS\IFSHLP.SYS
STACKS=0,0
Here's a screenshot of the mem command. http://i.imgur.com/n5QCxzC.jpg
How about you?
Reply 1 of 10, by keenmaster486
Hmm, I'll post mine when I get home today... both my autoexec and config are pretty complicated menu option deals 😁 I get LOTS of memory with QEMM, and I bypass the SB16 drivers with SBMIX 😀
I flermmed the plootash just like you asked.
World's foremost 486 enjoyer.
Reply 2 of 10, by oeuvre
Played around a bit more, used DOSMAX as well.
AUTOEXEC.BAT
SET SOUND=C:\SB16
SET CTCM=C:\CTCM
LH C:\DOS\ENVIMAX.COM N+
LH C:\DOS\SMARTDRV.EXE /X
@ECHO OFF
PROMPT $p$g
SET TEMP=C:\DOS
CONFIG.SYS
SWITCHES=/F
DEVICE=C:\DOS\HIMEM.SYS /NUMHANDLES=128 /Q /TESTMEM:OFF
DEVICE=C:\DOS\EMM386.EXE AUTO RAM HIGHSCAN I=B000-B7FF NOTR
DEVICE=C:\DOS\DOSMAX.EXE N+ P- R- U02 U08 U09 U0A U0B U0C U0D U0E U70 U72 U73 U74 U76 U77
BUFFERS=10
FILES=60
FCBS=1,0
DOS=HIGH,UMB
LASTDRIVE=G
STACKS=9,256
608K free conventional memory and 718K total under 1MB.
Reply 3 of 10, by keenmaster486
Ha, well I get 625K largest executable program size! Beat that! 😉
We should have a "How much memory can you get with X machine and so many device drivers?" thread 🤣
The difference between yours and mine is, I have no CD driver (separate menu option), and I use SBMIX (doesn't install into memory) instead of Creative's mixer drivers. Also I use QEMM but I have no idea how much of a difference that makes.
Reply 4 of 10, by melbar
configs for DOS mode on my Win95 maschine:
AUTOEXEC.BAT
SET TMP=C:\WINDOWS\TEMP
SET TEMP=C:\WINDOWS\TEMP
SET PROMPT=$p$g
SET winbootdir=C:\WINDOWS
SET PATH=C:\WINDOWS;C:\WINDOWS\COMMAND
C:\WINDOWS\a3init.exe
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:OPTICAL
LH C:\DRIVERS\CTMOUSE.EXE /R2
CONFIG.SYS (EMS)
DOS=HIGH,UMB,NOAUTO
FILESHIGH=30
BUFFERSHIGH=30
DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\WINDOWS\EMM386.EXE RAM
DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL
CONFIG.SYS (XMS)
DOS=HIGH,UMB,NOAUTO
FILESHIGH=30
BUFFERSHIGH=30
For EMS setting: 615K free conventional memory
For XMS setting: 556K free conventional memory
Reply 5 of 10, by keropi
Here are my multiple-choice files 🤣
They need some editing depending on the hardware combo, but you get the idea... not many fancy stuff included 😊
On my systems with UMBs activated I get more than 600kb of conventional memory, never needed more. Getting UMBs under DOS is mandatory 😀
[MENU]
MENUITEM=XMS
MENUITEM=EMS
MENUITEM=XMSCD,XMS with CD-ROM support
MENUITEM=EMSCD,EMS with CD-ROM support
MENUITEM=XMSUSB,XMS with USB mass storage support
MENUDEFAULT=XMSCD,60
[XMS]
DOS=NOAUTO,HIGH,UMB
device=c:\dos\himem.sys
;UMB1device=c:\utils\umbpci\umbpci.sys
;UMB2device=c:\utils\uram\uram.com R=AAAAAAAAAAAAAAAAAAAAAAAA
;UMB2device=c:\utils\uram\UMB.SYS c800-e800
;HOT-591P_device=c:\utils\umbpci\umbpci.sys
;SY-4SAW2_device=c:\utils\uram\URAM.COM R=..........77777777......
;SY-4SAW2_device=c:\utils\uram\umb.sys c800-ec00
[EMS]
DOS=NOAUTO,HIGH,UMB
devicehigh=c:\dos\emm386.exe RAM NOTR
[XMSCD]
DOS=NOAUTO,HIGH,UMB
devicehigh=c:\dos\himem.sys
devicehigh=c:\utils\cdrom.sys /d:CD0
[EMSCD]
DOS=NOAUTO,HIGH,UMB
[XMSUSB]
DOS=NOAUTO,HIGH,UMB
DEVICEHIGH=C:\UTILS\USB\usbaspi5.sys /int /all /v
DEVICEHIGH=C:\UTILS\USB\di1000dd.sys
[COMMON]
SHELL=C:\DOS\COMMAND.COM /E:512 /P
LASTDRIVE=Z
BUFFERS=11,0
FILES=60
STACKS=9,256
FCBS=1,0
;---- for dosgfx errors in installers , not needed because of fix8x14 ---
;country=030,737,c:\dos\country.sys
;devicehigh=c:\dos\display.sys con=(,,2)
;SW20PC_DEVICEHIGH=C:\SW20PC\OPL4TSR.SYS
@Echo Off
SET PATH=c:\utils;c:\DOS;c:\mtcp;c:\sb16;c:\sb;c:\scc-1;c:\lapc-i;c:\sw20pc;c:\ess;c:\opl3sax
GOTO %CONFIG%
:XMS
LH C:\utils\ctmouse.exe /o
GOTO SOUND
:EMS
GOTO SOUND
:XMSCD
LH C:\DOS\MSCDEX /d:CD0 /L:D
rem *** set quiet 8x cd-rom speed , enable correct ide/channel combination:
rem PRIMARY IDE /MASTER c:\utils\cdbq.exe /ide:1 /mode:1 /rate:1200
rem PRIMARY IDE /SLAVE c:\utils\cdbq.exe /ide:1 /mode:2 /rate:1200
rem SECONDARY IDE /MASTER c:\utils\cdbq.exe /ide:2 /mode:1 /rate:1200
rem SECONDARY IDE /SLAVE c:\utils\cdbq.exe /ide:2 /mode:2 /rate:1200
GOTO SOUND
:EMSCD
rem LH C:\utils\shcdx33c /d:CD0
GOTO SOUND
:XMSUSB
rem LH C:\DOS\SMARTDRV 8192 C+
GOTO SOUND
:SOUND
rem SB152_SET BLASTER=A220 I5 D1 T3
rem SB152_SET MIDI=SYNTH:1 MAP:E
rem SB152_SET SOUND=C:\SB
REM SB16_SET BLASTER=A220 I5 D1 H5 P300 T6
REM SB16_C:\SB16\DIAGNOSE /S
REM SB16_C:\SB16\MIXERSET /P /Q
REM SW60XG_C:\SW60XG\EFCON.EXE /type:0 /line:90 /mic:0 /midi:65
REM SW20PC_set OPL4DRV=-I7
REM SW20PC_set MAD16=C:\SW20PC\mad16
REM SW20PC_set AUTOTEST=C:\SW20PC\mad16
REM SW20PC_set BLASTER=A220 I5 D1 T4
REM SW20PC_C:\SW20PC\mad16\m16init /B
REM SW20PC_C:\SW20PC\kpcon /wait:1000 /type:2 /t2aor:2048 /t2aol:2048 /t2dpt:256 /t2mic:512
REM SW20PC_C:\SW20PC\opl4drv.bat
Show last 21 lines
REM SW20PC_C:\SW20PC\opl4drv.bat -r
REM ESS1688_C:\ESS\ESSCFG /I:5 /D:1 /A:220 /M:7 /B:300 /J:E
REM ESS1688_C:\ESS\ESSVOL /V:8 /L:8 /W:8 /M:0 /C:8 /S:8 /A:8
REM OPL3SAX_SET BLASTER=A220 I5 D1 T4
REM OPL3SAX_C:\OPL3SAX\SETUPSA.EXE /N
GOTO END
:END
rem ---- for dosgfx errors in installers , not needed because of fix8x14 ---
rem mode con codepage prepare=((737) c:\dos\ega2.cpi)
rem mode con codepage select=737
rem keyb gk,,C:\DOS\keybrd4.sys
rem -------------------------------------------------------------------------
SET TEMP=C:\TEMP
SET TMP=C:\TEMP
SET DIRCMD=/O
SET COMSPEC=C:\DOS\COMMAND.COM
REM MTCP_SET MTCPCFG=C:\MTCP\MTCP.CFG
🎵 PCMIDI mpu site buy+info
🎧 WIP Orpheus soundcard site
Reply 6 of 10, by oeuvre
Good stuff
Also I fiddled around some more, got it to 751K under 1MB and 619K free conventional!
Reply 7 of 10, by clueless1
I use a modified version of the one Phil provides in his DOS toolkit.
Autoexec.bat:
SET BLASTER=A220 I5 D1 T4 C:\AUDICIAN\SETUPSA.EXE /S @ECHO OFF PROMPT $P$G PATH C:\AUDICIAN;C:\DOS;C:\UTIL\PKZIP;C:\UTIL\SETMUL […]
@ECHO OFF
PROMPT $P$G
PATH C:\AUDICIAN;C:\DOS;C:\UTIL\PKZIP;C:\UTIL\SETMUL;C:\UTIL\UNIVBE
SET TEMP=C:\TEMP
GOTO %CONFIG%
:EMC
:XMC
:CMC
LH C:\DOS\MSCDEX.EXE /D:OPTICAL /L:D
:EM
:XM
:CM
:E
:X
:C
Config.sys:
REM DEVICE=C:\DRIVERS\AZTDOS\DRIVERS\EEPROM.SYS /88FC8401 [COMMON] REM DOS=HIGH,UMB REM FILES=30 REM BUFFERS=30 REM LASTDRIVE=F […]
[COMMON]
REM DOS=HIGH,UMB
REM FILES=30
REM BUFFERS=30
REM LASTDRIVE=F
[menu]
menuitem=EMC, Expanded memory + Mouse + CD-ROM
menuitem=XMC, Extended memory + Mouse + CD-ROM
menuitem=CMC, Conventional Memory only + Mouse + CD-ROM
menuitem=EM, Expanded memory + Mouse
menuitem=XM, Extended memory + Mouse
menuitem=CM, Conventional memory only + Mouse (WC3)
menuitem=E, Expanded memory
menuitem=X, Extended memory
menuitem=C, Conventional memory only (Infocom Games)
menudefault=EMC,10
[EMC]
DOS=HIGH,UMB
FILES=40
BUFFERS=30
LASTDRIVE=G
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
REM DEVICE=C:\DOS\EMM386.EXE RAM I=B000-B7FF
DEVICE=C:\DOS\EMM386.EXE I=E000-EFFF I=B000-B7FF RAM
[XMC]
DOS=HIGH,UMB
FILES=40
BUFFERS=30
LASTDRIVE=G
DEVICE=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL
[CMC]
FILES=40
BUFFERS=30
LASTDRIVE=G
[EM]
DOS=HIGH,UMB
FILES=40
BUFFERS=30
LASTDRIVE=F
DEVICE=C:\DOS\EMM386.EXE I=B000-B7FF RAM
[XM]
DOS=HIGH,UMB
FILES=40
BUFFERS=30
LASTDRIVE=F
[CM]
FILES=30
REM FILES=40 WC3
BUFFERS=30
REM BUFFERS=99 WC3
LASTDRIVE=F
[E]
DOS=HIGH,UMB
FILES=40
BUFFERS=30
LASTDRIVE=F
[X]
DOS=HIGH,UMB
FILES=40
BUFFERS=30
LASTDRIVE=F
[C]
FILES=40
BUFFERS=30
LASTDRIVE=F
DEVICE=C:\DOS\ANSI.SYS
DEVICE=C:\DOS\SETVER.EXE
All EMM386 options net me 617K free.
Extended with mouse and CD net me 584K free.
Extended with mouse only nets me 616K free.
Conventional with mouse and CD nets me 531K free.
Conventional with mouse only nets me 564K free.
Reply 8 of 10, by Jinxter
My config.sys and autoexec.bat - I made a video where i explain my settings.
https://youtu.be/iewwEzumCLQ
Check out my YouTube channel: Retro Erik https://www.youtube.com/channel/UCSUf7nCpwTgFbjGmcTYGZEQ
My collection: https://retro.hageseter.com
Reply 9 of 10, by Gered
For my 486:
config.sys:
[MENU] MENUITEM=NOEMM, No EMM386 MENUITEM=EMS, EMM386 Upper + EMS MENUITEM=NOEMS, EMM386 Upper Only MENUITEM=CODING, Dev (2MB ra […]
[MENU]
MENUITEM=CODING, Dev (2MB ramdrive, 4MB smartdrv, EMM386)
MENUITEM=WINDOWS, Windows
MENUDEFAULT=NOEMM,5
[COMMON]
SWITCHES=/F
BUFFERS=11,0
FILES=40
DOS=HIGH,UMB
STACKS=9,256
LASTDRIVE=Z
BREAK=ON
NUMLOCK=ON
[EMS]
FCBS=1,0
DEVICE=C:\DOS\EMM386.EXE HIGHSCAN AUTO RAM FRAME=DC00 I=E000-EBFF I=F000-F7FF
DEVICEHIGH=C:\DOS\VIDECDD.SYS /D:MSCD001
DEVICEHIGH /L:1=C:\DOS\SETVER.EXE
[NOEMS]
FCBS=1,0
DEVICE=C:\DOS\EMM386.EXE HIGHSCAN NOEMS I=E000-EBFF I=F000-F7FF
[NOEMM]
FCBS=1,0
DEVICE=C:\DOS\VIDECDD.SYS /D:MSCD001
[WINDOWS]
FCBS=1,0
DEVICE=C:\WINDOWS\EMM386.EXE AUTO RAM FRAME=DC00 I=E000-EBFF I=F000-F7FF
DEVICE=C:\WINDOWS\SMARTDRV.EXE C+
DEVICE=C:\SB16\DRV\CSP.SYS /UNIT=0 /BLASTER=A:220
[CODING]
FCBS=40,0
DEVICEHIGH=C:\DOS\RAMDRIVE.SYS 2048 /E
DEVICEHIGH C:\DOS\ANSI.SYS
[COMMON]
autoexec.bat
rem @ECHO OFF SET COMSPEC=C:\COMMAND.COM […]
rem @ECHO OFF
PROMPT $P$G
PATH C:\;C:\DOS;C:\APPS\AURORA;C:\APPS\DP2
@GOTO %config%
:EMS
@GOTO COMMON
:NOEMS
@GOTO COMMON
:NOEMM
@GOTO COMMON
:WINDOWS
PATH C:\WINDOWS;%PATH%;C:\BC4\BIN;C:\TASM\BIN;C:\TP\BIN;C:\TD;C:\QB45
SHARE
@GOTO COMMON
:CODING
PATH %PATH%;C:\WATCOM\BIN;C:\WATCOM\BINB;C:\TP\BIN;C:\TD;C:\BC\BIN;C:\QB45
C:\DOS\SMARTDRV.EXE C+ /N /F 4096
SET TMPDIR=D:
SET TMP=D:
SET EDPATH=C:\WATCOM\EDDAT
SET INCLUDE=C:\WATCOM\H;C:\WATCOM\H\win
SET WATCOM=C:\WATCOM
SET DPMIMEM=MAXMEM 2048
@GOTO COMMON
:COMMON
SET ULTRASND=260,7,7,7,7
SET ULTRADIR=C:\ULTRASND
SET TEMP=C:\TEMP
SET CTCM=C:\CTCM
SET SOUND=C:\SB16
C:\SB16\DIAGNOSE /S
C:\ULTRASND\ULTRINIT.EXE -dj -eo
SET WATTCP.CFG=C:\DOS
SET MTCPCFG=C:\DOS\MTCP.CFG
SET HLP=C:\HELP\HELPPC
LH /L:1 C:\DOS\3C509.COM 0x60
LH /L:2 C:\DOS\MSCDEX.EXE /D:MSCD001 /L:E
LH /L:2 C:\DOS\CTMOUSE.EXE
LH /L:1 C:\DOS\DOSKEY.COM
@IF "%CONFIG%"=="WINDOWS" WIN
:END
486DX2-66/16MB/S3 Trio32 VLB/SBPro2/GUS
P233 MMX/64MB/Voodoo2/Matrox/YMF719/GUS CD3
Duron 800/256MB/Savage4 Pro/SBLive (IN PROGRESS)
Toshiba 430CDT
Reply 10 of 10, by Mephusto
I wish I understood what these all mean. I never grew up with Dos, so I don't know how to use it. I am trying to learn now and trying to get my first dos machine built. But I have do idea what I'm doing 🤣. Hopefully I'll be able to post my own settings in here soon
