keenmaster486 wrote:Well, yes - but I'm headed off to college and the printer I'm going to have is pretty much guaranteed to be a standard inkjet al […]
NJRoadfan wrote:They still make laser printers with PCL and PostScript support. Both are supported by Windows and by the vast majority of DOS software.
Jo22 wrote:Uhm, why do you worry so much ? Printers are the most supported piece of hardware with the longest life span.
Besides, old style printers never really went out of prodution (doctors still need them).
In fact, you can get fairly new dot-matrix printers, for example.
Well, yes - but I'm headed off to college and the printer I'm going to have is pretty much guaranteed to be a standard inkjet all-in-one (HP Officejet, or something other such equivalent style).
HP isn't going to support those latest printers on Windows 98, are they? Maybe they are and I'm just spouting hot air.
Maybe not; this comes from an "HP Support Agent" on their forums:
The earliest Operating System that currently has print drivers is Windows XP.
Ah, okay, that makes sense. I thought you were worried about new printers in general.
Didn't know you have to use an existing, unsupported model.
In this case you've got to try older drivers or one of the standard languages.
Chances are good that it supports either PCL (raster based) or its "Brother" language (pun intended!) HPGL (vector based).
Back in time this worked at least for the Deskjet and LaserJet series I used (Deskjet 500c, for example).
But saying this, I've never tried this with the more modern models. In worst case, you're confronted with one of these cheap GDI-Printers (aka Windows-Printers).
Unfortunately they don't support anything at all. In this case your last hope is to get one of HP's "Universal Printer Drivers" to work.
Older versions can be found on ftp://ftp.hp.com/pub/softlib/UPD/
Here are a few links I've found while searching the web. Nothing special, though:
HP Printers and HP Plotters - PostScript (R) / PCL Comparison
"What is PostScript?" "When would you need to use PostScript?" "What is PCL?"
http://h20564.www2.hp.com/hpsc/doc/public/dis … emr_na-bpo00141
Understanding HPGL
"Although HPGL was intended for HP's line of pen plotters, variants have found their way into inkjet and laser printers.
PCL, on the other hand, is strictly used by HP for its raster devices and is very slowly loosing favor to PostScript
and Windows-based direct-GDI."
http://www.bae.ncsu.edu/people/faculty/seaboch/hpgl.htm
Information on Printers from HP
"This document contains information on the capabilities that are supported on printer hardware from Hewlett-Packard (HP)."
* It also mentions the "Epson ESC/P2" printer language I've never heard of. It seems it was used by other manufacturers, too. Interesting.
http://www-01.ibm.com/support/docview.wss?uid=nas8N1019534
HP's History Of Printer Command Language (PCL)
History about PCL. It says that PCL5 from the mid-90s got "HP-GL/2" compatibility.
Cool, didn't know that. That feature was added a bit late, though.
http://www.csgnetwork.com/hppclhist.html
