First post, by MrEWhite
- Oldbie
Hi, I have a Tualaron at 1.1 GHz and if I run it at 100 MHz FSB, which should work due to the Vogons Wiki. The card doesn't work at all (random squares on the screen). Does anyone know a fix? The card works perfectly at 66 MHz FSB.
