First post, by SBB
Hi all
I added an Orchid Righteous card to by DOS build, and im trying to get GTA working in 3DFX mode.
Inititally, I received an error about a missing DLL. So after a bit of reading online I downloaded the following driver and copied GLIDE2X.OVL from it http://www.falconfly.de/downloads/voodoo1-30100.zip to C:\VOODOO and added this to my PATH env variable.
However, when I launch the game I hear the relay in the card click but then I get a screen that looks like this:
http://i.imgur.com/ldN28dh.jpg
Not good!
I tried another version I found from an Orchid driver zip file from the falconfly site but this one just complains the DLL is missing.
Im pretty sure the card works OK as I had it running under win95 previously.
Reply 1 of 4, by SBB
Managed to fix it using a file I found from the "GTA 3DFX Demo"
Put this in the "GTADOS" folder and you're good to go 😀
Reply 3 of 4, by SBB
I've put in a report for it to be moved 😀
Reply 4 of 4, by uniQ
Sorry for digging up this old post but I recently tried to run GTA 1 with 3Dfx in real dos and it gave me a headache.
Turns out you need an old version of GLIDE2X.OVL for it to run but the system also needs a minimum of
32MB of RAM or you will end up with the infamous "FATAL ERROR: UNABLE TO LOAD DLL" - which is kind of misleading.
I also wrote a short blog post on this if anyone is interested:
https://unbit.de/gta-1-3dfx-under-native-msdos-6-22/
My Retro Systems
