First post, by snorg
I've got an old 386 Baby AT board that I want to mount in an ATX case. I thought I'd get lucky and be able to use the existing mounts but absolutely none of them match up.
Am I going to need to drill/tap for the brass standoffs so that I can properly mount it? Or would I be better screwing the standoffs into a thin piece of plexi and then screwing that into the case?
How exactly would you drill the aluminum so that you can screw in the brass standoffs? I know that if I just use a regular bit it probably isn't going to work.
I want to maybe have a crack at getting this box going next weekend and want to properly secure the board. Let me know what you think.
