First post, by Galahad
How do ISA riser cards work, on classic/vintage PCs with available ISA slots? For instance, do they fit into an existing ISA or PCI slot horizontally, and then allow you to fit additional ISA cards vertically into the riser card than the maximum number of ISA slots the vintage PC supports, without the riser card? For example, my classic gaming/MIDI PC has 2 ISA slots, but if I bought a ISA riser card, would it allow me able to support up to say 3-4 ISA cards in the same PC, instead of only 2? Not sure exactly how it would work, can't seem to picture it in my mind, 🤣. And are classic DOS games able to successfully detect and work with ISA riser cards?
Also sorry if this comes across as a very basic or newbie question; unfortunately, I am rather inexperienced, when it comes to operating hardware 😊
Reply 1 of 11, by BloodyCactus
they just make the length of the bus longer. you can get like 20 slot backplanes on ebay. I dont know at what length you start getting reflections on the bus or that, but ISA is a slow bus.
the only thing is on the isa bus, you have limited number of IRQ's to share between all the slots.
riser cards are passive. they dont need drivers, detection etc.
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
Reply 2 of 11, by Galahad
Many thanks for the awesome and helpful info! 😀
Reply 3 of 11, by brostenen
This means that a standard ISA riser card, can be plugged into every motherboard that has ISA slots?
Example... If one has an old ISA riser card from around 1988, then it will work on a SS7 board?
Reply 4 of 11, by BloodyCactus
yes.
Reply 5 of 11, by yawetaG
I've always wondered, what were those huge backplanes used for? Were there really systems that used all slots at once, or were they for systems that had a lot of interface cards that were coupled to specific programs and therefore no conflicts occurred?
Reply 6 of 11, by BloodyCactus
industrial control machines, data acquisition, test racks etc. lots of things that were not 'PC' used ISA bus layouts, and/or isa slots.
Reply 7 of 11, by pan069
How likely is it that unbranded ISA risers are "universal"? I mean, e.g, given a 3 slot ISA riser, would it fit a case designed for a 3 slot riser?
I can imagine that a riser manufactured by e.g. Dell would be more likely to only fit a specific Dell manufactured case.
Reply 9 of 11, by pan069
Interesting. I have two low profile cases on the way and I'm on the lookout for 3 slot ISA risers. I have found some on eBay but they somehow are CRAZY expensive.
If you have "tons" of them, would you be open/willing to part with 2 of your 3 slot risers? Happy to pay something and I'll obvious will cover postage... 😀
Reply 10 of 11, by Caluser2000
I had a slimline Olivetti 486 which had a ful size vlb mobo with 5 slot riser. 3 isa slots one side and two the other. A total waste of mobo.so stripped for the time I aquired a vlb multi i/o and video card.
Reply 11 of 11, by derSammler
I don't think I have any 3-slot risers, but I have to check. Most of them have 5 slots (3 16-bit slots on one side and 2 8-bit slots on the other).
Also note that shipping from Germany to Australia is f*cking expensive. The absolute minimum is 16€ without any tracking or insurance. With tracking or insurance, it's 47€.
