First post, by Jade Falcon
Rank BANNED
BANNED
I have a sil SIL3114 sata card with the newest ide bios. I installed 2k on a 140gb drive and insataled the drivers for the card by pressing f6 when starting the Windows 2k installation.
After the system robots For the first time dearing the install (after the blue gray screen) I get this error.
The attachment image.jpeg is no longer available
Any ideas?
Reply 1 of 8, by Jade Falcon
Rank BANNED
BANNED
Ok getting somewhere. I loaded up a stock boot.ini from another system and got this half way into booting.
Reply 2 of 8, by Jade Falcon
Rank BANNED
BANNED
no one?
I know this has to be something with the boot.ini
Reply 3 of 8, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Did you try to boot from the old card (having the new card plugged in) and installing the driver from there?
1+1=10
Reply 4 of 8, by Jade Falcon
Rank BANNED
BANNED
That is a very good idea, sadly I already tried it last night. It did not work. I even installed both the cards drivers too.
Also I can't boot from a CD (ide or sata) with a hdd attached to the card. I have to boot up the system without a hdd and then plug the hdd in when the windows install starts. I get a message about the hdd right before the installer starts. I'll post exactly what it say tonight.
Reply 5 of 8, by agent_x007
Are you using latest drivers for Floppy ?
Reply 6 of 8, by Jade Falcon
Rank BANNED
BANNED
Yes. I tried older drivers too.
Reply 7 of 8, by darry
This may not be applicable to your situation, as your are using a SIL3114 with its own driver rather than the native IDE driver, but it might be worth a look.
Windows 2000 seems to have issues with LBA48 support (for drives greater than 127 GB) up to service pack 2 (inclusively).
Are you using a third party partitioning/format tool before installing ?
You might want to look at the following links and/or try a smaller disk .
https://support.microsoft.com/en-us/kb/305098
http://www.msfn.org/board/topic/75713-48-bit- … on-win2k-setup/
http://www.hardwareheaven.com/community/threa … on-limit.79706/
Reply 8 of 8, by Jade Falcon
Rank BANNED
BANNED
That's a good think to bring up, but if that was the problem then why would the VIA card work with the same hdd? Maybe the sil driver don't have lba support?
Also I'm using the formatting the hdd with the windows installer.
