First post, by konc
Hi all,
I've been searching for quite some time now the floppy which came with the ATI Small Wonder graphics card. It's more of a utilities disk (1 5.25" DD floppy) containing a very handy tool: it allows you to change the mode (Hercules/CGA -otherwise configurable through dip switches) through software until next reboot.
Does anyone have it? Either just the contents or a proper disk image.
(I suppose it's not a problem to share this, right? I mean it's like a drivers disk, not commercial software).
Thanks!
Reply 1 of 11, by Scali
I have the contents, but it was not on a separate disk for me. It was a subdirectory of the MS-DOS floppy from my Philips P3105.
I'll upload it somewhere.
Reply 2 of 11, by konc
Excellent, thanks a lot. Of course the contents are more than enough.
On a Hyundai PC clone which also came with this card it was a separate disk, visually different, labeled "graphics utilities" or something similar. It wasn't even in the same envelope with the rest "system disks" containing MS-DOS.
On another clone, the exact same contents where on a floppy having ATI's name on its label.
That's why I'm assuming there was some "official" disk, although it seems now that it has been distributed in many different ways.
Reply 3 of 11, by Scali
Here's the images of the two floppies that came with my Philips P3105: https://www.dropbox.com/s/1f8g7g0cwdr7ge4/Phi … sP3105.zip?dl=0
See the VIDEO subdirectory on the MS-DOS 3.21 disk.
Reply 4 of 11, by konc
That's it, MS.COM! Just tried it and it works. You can have the card configured for Hercules from the dip switches enjoying clear text, run ms.com, select #4 and run a CGA game without loading SIMCGA.
Everything is in Dutch though and by the very simplistic appearance it looks like an older version of what I had, but it does the job. Thanks again!
Reply 5 of 11, by Scali
Yea, I believe you can even pass it command line parameters. So you could make a batch file that does something like this:
@ECHO OFF
C:\VIDEO\MS.COM C80
RUNGAME
C:\VIDEO\MS.COM MG1
At least, that's what I seem to recall.
Reply 7 of 11, by konc
...aaand the ATI disk I had memories of, just as I was starting to believe I'm getting too old and loosing it, revealed itself. It was lying under our eyes all this time.
This is the full/ATI branded Graphics Solution disk from 1987, as found at minuszerodegrees.net (a site of amazing content I must say).
http://www.minuszerodegrees.net/manuals/ATI%2 … sion%201.00.zip
4.69 KiB
It's the disk which came with my first PC clone mentioned earlier having an ATI logo on the label. It's not showing on the dosbox screenshot I just took, but it actually has a menu bar 😀 It's a slightly later version of what Scali kindly shared.
Reply 9 of 11, by dr.zeissler
wow that's cool. That means dip-switches stay hercules, monitor stays hercules,
but software emulates and displays CGA...that's cool! no ghosting, no scanlines,
wow that's REALLY cool. ...but useless for my euro pc with HGC/CGA Paradise-Chip 🙁
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 10 of 11, by Scali
I believe the Paradise can do the same thing.
Reply 11 of 11, by dr.zeissler
Thx scali, that would be a killer-feature 😀. So I only need the tools for that paradise chip.
It's a Paradise PVC4 38307c, the same chip is used in a commodore PC-10-III and labeled "AGA" Graphics.
Perhaps I can get the Paradise Tools from that machine...
https://www.flickr.com/photos/94839221@N05/26 … 57665135854734/
