First post, by michaelmak
Hi all,
I want to create different DOSbox mapper files for different game.
After I have changed the default key mapping and press SAVE button, it doesn't ask me where to save and the name of the new key mapper ??
I find that the new key mapping affect all games insteads of the single game which I expect. 😠
From the configuration file "dosbox-0.74.conf", there is a setting "mapperfile=mapper-0.74.map".
But I cannot find this mapper file from my harddisk.
Please tell me how can I save different key mapperfile for different games ?
Thanks.
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
just click save from the mapper and it will be created.
Copy/rename it and update the configuration file that you are using to use the new name.
Water flows down the stream
Reply 3 of 5, by michaelmak
Hi Qbix,
Please tell me where I can find the mapper file so that I can copy / rename it.
Thanks.
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
it appears once you press save, in the same place as dosbox-0.74.conf
Reply 5 of 5, by michaelmak
Hi Qbix,
Thanks.
