Blood stuttering in DOS?
First post, by MrEWhite
So, on my Windows 98/DOS machine, my SB16 CT2290, I getting massive amounts of stuttering when first starting. After the first minute or so, the game plays nice and smooth. It works perfectly under Windows though. Is there a fix?
Reply 1 of 20, by badmojo
Are you using the MPU-401 on that SB16?
Reply 2 of 20, by MrEWhite
Nope, using the Soundblaster music option. That's why I made this thread exactly.
Reply 3 of 20, by MrEWhite
Also, just noticed that I posted this in the wrong subforum! Could an admin move this to Marvin?
Reply 4 of 20, by Jorpho
The question is unclear. The fix would appear to be to run it under Windows..?
Reply 5 of 20, by Stiletto
Moved to Marvin.
do the Fandango!" - Queen
Stiletto
Reply 6 of 20, by MrEWhite
I kinda just want to boot into DOS at start up, so I can get right to the games.
Reply 7 of 20, by clueless1
Still not totally clear to me. So you're saying in real DOS, or MS-DOS Mode is where it takes a minute for the stuttering to smooth out? I get that when you run from Win98 there is no stuttering at all.
Reply 8 of 20, by MrEWhite
Exactly, after running around and shooting and blowing stuff up, the stutter stops after a minute or so.
Reply 9 of 20, by amadeus777999
Could the stuttering have to do with caching of disk access? I remember having initial lag in pure DOS mode when playing Doom/Blood and Co. even on fast A64s as some data is always loaded per request and not at startup.
In windows98 the subsystem is caching disk access - "dos mode window" or not, you get way less initial lag.
Reply 11 of 20, by MrEWhite
clueless1 wrote:
So maybe try a small smartdrv cache?
How would I do this?
Reply 12 of 20, by clueless1
From the DOS prompt type 'smartdrv /?' for instructions and switches.
If you just run:
smartdrv
at the command prompt, it will use all available extended or expanded memory.
You can try different cache sizes such as
smartdrv 256
smartdrv 512
smartdrv 1024
and see which works best for you. Keep in mind it may cut into your conventional memory if it can't all fit in upper memory.
Reply 13 of 20, by MrEWhite
Didn't help at all, still getting the stuttering.
Reply 14 of 20, by badmojo
Post your config files if you're able to, something might jump out.
Reply 15 of 20, by Kerr Avon
This isn't what you wanted exactly (it's not a fix for the original game), but there is a free, 99.9% accurate port of Blood to Windows, via the eDuke32 game engine (a Windows port of the Duke Nukem 3D engine), and it's fantastic. It has proper mouse support, fully configurable controls, support for high resolutions, etc, so is much more convenient to use than the DOS game Blood.
Just download BloodCM_v02.2016.zip from:
http://m210.duke4.net/index.php/files
You don't even need any files from Blood, everything is in the zip file.
The only disadvantages are that it doesn't (yet?) support fan made mods/levels, or the later official expansion packs.
Reply 16 of 20, by MrEWhite
Blood config files or the autoexec/config ones?
Reply 17 of 20, by Jorpho
I presume the autoexec/config ones.
How much RAM is in this machine? Just for troubleshooting purposes it might be amusing to see if the stuttering vanishes if you run it from a RAM drive (though that is not especially practical).
Reply 18 of 20, by badmojo
Yes the autoexec / config files - if it works OK in Windows but not in DOS on the same thing, then perhaps it's a config / memory management issue.
Reply 19 of 20, by MrEWhite
I have 512MB. I'll post my config files later tonight.
