First post, by brinstar117
I have an old laptop with a fresh install of MS-DOS 6.22
ThinkPad 385XD
Pentium 1 233MHz
32MB
2GB
800x600 screen that's currently at 640x480
The software I'm trying to run needs to display 80 columns by 50 rows. But when I tried running the following:
MODE CON: COLS=80 LINES=50
I get a message saying I need to install ANSI.SYS
I currently have an ANSI.SYS file in my C:\DOS directory, but it is blank. What do I need to put into this file? Thanks in advance!
EDIT:
I solved it:
I needed to load ansi.sys driver in order to get it to work.
For future reference I edited my config.sys file to read:
DEVICE=C:\DOS\SETVER.EXE
DEVICE=C:\DOS\HIMEM.SYS
DOS=HIGH
FILES=30
devicehigh=c:\dos\ansi.sys
This might be straightforward for you guys, but I've never had the benefit of using a native DOS computer before. 😊
Reply 2 of 2, by Stiletto
Moved.
do the Fandango!" - Queen
Stiletto
