First post, by Jade Falcon
So I been doing some thinking about raid with newer sata 3 ssd's in older systems with sata 1, a pci sata card or sata to pata convertor.
Would raid 0 speed up the drive's read wright on such a setup? and would raid 1 slow the drives down?
My thoughts are that the drives speed, if impacted, would be so little that you'd only see them on benchmarks when comparing raid 1 to 0.
Such setup would bottle neck a sata 3 ssd to such a extent that nothing you do will speed up or slow down the drives to a noticeable point.
What are your thoughts?
