First post, by GuyTechie
I did some searching and found a couple of threads in regards to this issue, but none brought up using DISKPART to fix the issue. I recently bought one myself, and found that some SD/microSD cards doesn't seem to boot even after using FDISK to clear everything out.
I thought it had to do with some SD cards were made, but I found the DISPART/CLEAN trick that made every card I had boot!
Before using the SD Card in the adapter/retro PC, mount it on a modern Windows machine. The command we're interested in using is DISKPART, so I believe the earliest Windows that may have it may be 2000 or XP, but definately Vista and up has it.
BE CAREFUL YOU HAVE THE RIGHT DISK OR YOU WILL DELETE EVERYTHING ON THE WRONG DRIVE! Should be easy if the SD Card is the smallest drive in the system.
Open up the command line (cmd.exe) as an administrator. Type "DISKPART" and hit enter.
Then follow the example below. In my example, Disk 2 is my SD Card (2 GB card).
DISKPART> list disk
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 894 GB 1024 KB *
Disk 1 Online 2794 GB 0 B *
Disk 2 Online 1886 MB 0 B
DISKPART> select disk 2
Disk 2 is now the selected disk.
DISKPART> clean
DiskPart succeeded in cleaning the disk.
DISKPART> exit
Leaving DiskPart...
In the example above, these are the commands you type:
DISKPART
list disk
select disk 2 <---- Make sure you are selecting the right disk!!!!!
clean
exit
Take the SD Card out, put it in your SD to IDE adapter of your retro PC. Boot up your DOS or Windows 98 install disk and use FDISK and FORMAT like you normally would.
I hope this helps someone out! It saved me a lot of trial and error trying to test which cards allowed booting and which ones doesn't. It turns out they all did, as long as you "clean" them.
Reply 1 of 4, by PhilsComputerLab
fdisk/mbr always fixed this for me.
YouTube, Facebook, Website
Reply 2 of 4, by GuyTechie
In an old thread, there was still report of Operating system not found after using sys C:, then fdisk /mbr.
I think using the DISKPART/CLEAN method wipes not just the MBR but also hidden sectors.
I didn't to revive an old thread, so I posted this one. But here's the one I was reading:
SD to IDE not booting - any experience?
I forgot about the fdisk /mbr trick myself before reading the thread. Old dog, old DOS tricks. 😀
Reply 3 of 4, by matze79
This deletes everything for sure.
Connect SDCard IDE Adapter to your Computer
Run DBAN Live Linux.
And it wipes everything out.
Or use:
dd if=/dev/zero of=/dev/mysdcardreader as command in shell (root).
Replace mysdcardreader with corresponding device.
Reply 4 of 4, by GuyTechie
Hmm... it's still possible for some SD cards to not boot after these methods. I have a 256MB SD Card that doesn't boot, nor a 32 MB MMC.
