First post, by stamasd
Today while rummaging through some old boxes with odd parts I found this little guy.
I remember removing it from a computer that was getting scrapped from the place I worked at the time, sometime in 2001 or 2002. It was a PII-266 desktop, Micron brand but I don't remember the model number. I saw that it had this little daughterboard attached and decided to keep it. I actually wanted to keep the whole computer but wasn't able to. I remember that I wanted to figure our a way to use it in another computer but couldn't, and then it sat in that box for another 14 or 15 years until I found it today.
Here are pictures:
https://dl.dropboxusercontent.com/u/107843342/ymf704/1.jpg
https://dl.dropboxusercontent.com/u/107843342/ymf704/2.jpg
https://dl.dropboxusercontent.com/u/107843342/ymf704/3.jpg
It attached to the motherboard through two 6-pin connectors, one of which had a hole plugged. I can't find any information about it online.
I wonder if I can use it somehow...
(edit) I found this thread elsewhere, which didn't lead to anything... apart from that, no information. https://www.cemetech.net/forum/viewtopic.php?t=6961
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
