First post, by Rhuwyn
Hey guys,
I recently aquired a nice Pentium II based laptop which looks to me that it could be a nice DOS/Early Windows retro gaming laptop. Right now it has a Build of Windows 98 on it. I want to do a clean build but really dont want to have to source all the drivers. I know there are tools designed to backup drivers but I've never used any of them. Some of them seem they aren't legit and are tied to malware.
Has anyone by chance used any of these tools or have any recommendations on legit ones?
Reply 1 of 3, by Jorpho
Have you tried at all? Since it's a laptop, all the drivers are likely to be in one place.
I wonder if you could rename the Windows directory, reinstall Windows, and then direct Windows to the renamed directory for each of the drivers? Assuming there's enough space, anyway. (You should probably back up the entire hard drive anyway if you're worried about being unable to find something on there again.)
Reply 2 of 3, by Rhuwyn
Yeah thats what I'm going to do in liu of another solution. I actually want to install a larger hard drive which was somewhat of a separate discussion. I am sure I can accomplish what I am asking by just backing up everything but for the future I was curious if there was a more elegant solution. Drivers tend to put things in all sorts of places so it's not as simple as backing up the windows directory, at least not in all cases.
Reply 3 of 3, by CkRtech
If you are going to use a larger hard drive, you could pull the current one as-is and put your new one in place for a fresh install. You could hook the old drive up via USB (as needed) for drivers or copy over any data you need (Windows or other directories) since you have more space and file away the old drive as a backup of the old install should you want to revert. Older USB, but serviceable.
