First post, by UltimaPlayer12
There are times I attempt to boot into MS-DOS mode with a custom shortcut within Win98 that generates an autoexec.bat and config.sys, and it succeeds. Sometimes this happens multiple times in a row. However, I hit a point where sometimes it just doesn't want to reboot. It seems that maybe something with my display drivers are messed up or perhaps it is an issue with MS-DOS mode corrupting my files, as booting into the CLI on boot-up using F8 and checking them shows garbled text.
I'm running an S3 Virge 2MB graphics card, on an ASUS P5A motherboard. I do not have an option to reserve an IRQ for VGA, but I have set the IRQ reserve to 11 on the PCI slot for my GPU and this hasn't resolved the problem.
If this will help, my config and sys files are as follows
autoexec.cfg:
GoTo %config%:EMC:XMC:CMCSET SOUND=C:\SB16SET CTCM=C:\CTCMC:\CTCM\CTCM.EXEC:\SB16\MIXERSET.EXE /P /QLH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:OPTICAL:EM:XM:CMLH C:\DRIVERS\CTMOUSE.EXE /R2:E:X:C
config.sys:
[COMMON]DOS=HIGH,UMB,NOAUTOFILES=30BUFFERS=30[menu]menuitem=EMC, Expanded memory + Mouse + CD-ROMmenuitem=XMC, Extended memory + Mouse + CD-ROMmenuitem=CMC, Conventional Memory only + Mouse + CD-ROMmenuitem=EM, Expanded memory + Mousemenuitem=XM, Extended memory + Mousemenuitem=CM, Conventional memory only + Mousemenuitem=E, Expanded memorymenuitem=X, Extended memorymenuitem=C, Conventional memory onlymenudefault=EMC,10[EMC]DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFFDEVICE=C:\WINDOWS\EMM386.EXE RAMDEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL[XMC]DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFFDEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL[CMC]DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL[EM]DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFFDEVICE=C:\WINDOWS\EMM386.EXE RAM[XM]DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF[CM][E]DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFFDEVICE=C:\WINDOWS\EMM386.EXE RAM[X]DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF[C]
These are slightly modified versions of PhilsComputerLab's provided configurations with his MS-DOS tutorials, used for a working mouse and audio.
Note: I posted this in the wrong area of the forum originally, and have no way to delete it. If an admin would like, they can remove the original. I apologize for having posted in the wrong place.
The Beast 2.0:
CPU: AMD K6-III 450MHz GPU: Nvidia FX 5600 128MB HDD: 20GB (Seagate?) Mobo: ASUS P5A-B RAM: 512MB Sound Card: SB 16 PnP ISA OS: Windows 98 SE
