First post, by ChAoS Overlord
- Newbie
Hi, I succesfully got phantasmagoria II to work with dosbox. But when I try to change to the second CD, dosbox complains at the moment that I click the continue button.
Dosbox tells me the wrong cd is in place and that I should put the previous one back in.
I mounted everything in an orderly fashion
mount e e:\ -t cdrom -usecd 0
is the line I used for phantasmagoria
the -ioctl paramater (I use Windows XP SP1) doesn't help either.
