Glidos and plama pack 3dfx patch
First post, by Teller
Just tried 3dfx patch for Blood Plama Pack with Glidos 1.24 works well
Vista 32 Bit (SP 1)
Intel Quad 2.4 Gig
4 Gig RAM
Dual SLi NVidia G-Force 9600GS
Forceware 174.90 (latest available)
Video Bios 64.94.21.00.26
Reply 2 of 21, by Teller
i was using the one avalable from your setup page I am on my Win98 machine now cos my gfriend is talkin to her mom
same page but link was not there when i got interested
Blood R1120 is the patch I use when i talk to you about GLIDOS
Vista 32 Bit (SP 1)
Intel Quad 2.4 Gig
4 Gig RAM
Reply 4 of 21, by Glidos
Why do you want them? If the moves from v1.24 to v1.27 have caused problems, I need to fix them, otherwise Glidos is going to degenerate. That would be particularly bad for you, when Glidos v1.28 has some magic feature you want, but still has the problems that make you want to use v1.24.
Reply 6 of 21, by Teller
Sorry ill shut up about older versions and look forward to v1.28
You are doing a great job
Vista 32 Bit (SP 1)
Intel Quad 2.4 Gig
4 Gig RAM
Reply 7 of 21, by Glidos
No, its very important that problems like this are brought up. I very much appreciate your input. And there's no way that v1.28 will be any faster without your help. But I don't want to cure people's problems by handing out old versions. Its important that I find out what the cause is.
Reply 11 of 21, by Kaminari
Caleb, try using different previous versions of OpenGlide before assuming it's a problem with the latest Glidos releases. The library that was distributed with Glidos 1.24 was OpenGlide 0.09rc6, you might want to give it a try with Glidos 1.27. Just another thought: try disabling mipmapping in your OpenGlide.ini configuration file.
Oh, and make sure you don't have any other Glide2x.dll / Glide2x.ovl in your game and system32 directories.
Reply 14 of 21, by Teller
swapped pollpipe.dll
Glidos 1.24 runs slow
Glidos 1.25 runs with a good speed
You found it
Glidos 1.27 also runs faster with same file swap
Vista 32 Bit (SP 1)
Intel Quad 2.4 Gig
4 Gig RAM
Reply 18 of 21, by Glidos
It was a different cause this time. In both cases I was trying to have Glidos make less intensive use of the computer. Obviously didn't do enough testing.
For those who don't have a copy of v1.24, here's PollPipe.dll
    PollPipe.zip
    13.97 KiB
    211 downloads
