First post, by Jade Falcon
I got a problem here, my dual sk604 setup has hyper threading enabled Xeons but 2k does not see the seconds threads, even cpuz does not see hyperthreading.
If I remove one of the 2 cpu's 2k can use hyperthreading and centOS can use/see hyperthreading with both cpu's.
So anyone have any ideas ? would I need to install SP4 or something? or will I be stuck with a server version or XP?
