update glidos
First post, by marionf
Hi,
Ik have Glidos 1.25, how can I update my version to 1.26 or higher?
Reply 3 of 10, by Glidos
Yes. When you log in to the unlock service on the web site, you will see a list of previous GlidosID's for which you have unlocked. Your current ID should be amongst them. You can click the button to the right and regenerate the unlock code.
Another way is to keep a copy of the file Authority.txt from the Glidos folder, and replace it after reinstalling.
Reply 5 of 10, by Glidos
Not sure. I think I changed the way texture packs work between 1.25 and 1.26 so you may need to redownload the caves levels. Still what you are seeing shouldn't happen.
What Graphics card by the way?
