First post, by maxrate
Hi everyone, I recently built a 486 computer. I used to work at a computer store in my teens and I had to build these all the time. Was hammering out about a dozen computers a week (part time job).
Reason for my writing; I am having trouble getting Doom (either the shareware or the registered full version) to work. The game starts up, I can use the menu for a few seconds, and it hangs/stops dead. I have to press the power button.
Sometimes, if I move the cursors up and down quick enough I can start the game play. It will work for a few minutes then hang.
Very odd. I have tried some many BIOS settings, different video adapters, different RAM, I'm not sure what is wrong.
Not sure what information I should be posting otherwise. I'd hate to see this 'new' 486 computer be trashed because of something silly. I can't even get that old Dominos Pizza game 'avoid the noid' to run - but other programs (including my old BBS software) run just great.
Anyone have any troubleshooting ideas? Anything I could post here?
Thanks!
Reply 1 of 15, by keenmaster486
Hmm... it'd be nice if you'd post the full specs of your system.
VGA card problem maybe?
Try swapping/reseating RAM sticks.
World's foremost 486 enjoyer.
Reply 2 of 15, by maxrate
I will do - I left the computer at my workshop. I'll bring it home tomorrow, so I can take some pictures and take an inventory of all the parts. I bought the mobo on eBay a couple of months ago. Basic machine with DOS 6.22 - was fun to put together!
Reply 3 of 15, by clueless1
Could it be a stability issue? Maybe try BIOS defaults or even reducing timings to slowest to see if it gets more stable.
Reply 4 of 15, by maxrate
I played with many BIOS settings - even put 'defaults' back in. I messed with the timings in the BIOS. I've changed video cards, I'd put different RAM in (even a single 8 MB stick). When I run basic DOS apps, all is well - no crashing it seems. I've made sure the computer is not on turbo mode too. I do not recall DOS ever crashing much at all back when these machines were current - it was pretty rare (based on my memory from a long time ago!) I've even disabled the external cache too.
Reply 6 of 15, by chinny22
Rekon your on the right track.
Strip the PC back to basics. Video, Ram, HDD, that's it
Boot into dos bypassing config.sys/autoexec.bat
See if Doom runs now, and then slowly start building the PC up from that point.
Reply 7 of 15, by Rawit
Could you try Heretic shareware and see if that runs?
YouTube
Reply 8 of 15, by James-F
Yep, what chinny22 said.
Try to disable the Sound in Setup.
Remove Sound Blaster card completely.
Remove the Mouse.
Reply 9 of 15, by matze79
Try using Doom+ Executable, and see if it works. https://sourceforge.net/projects/prboom-plus/ … .2.zip/download
Maybe its a compatiblity issue.
Do other Games also have this Problems ? try Descent.
Have you tested your memory subsystem ? run memtest86 2.0
Reply 10 of 15, by Alex_C
Switch off "Turbo Switch Function" in the BIOS, if it exists. This cured a similar problem with Doom for me, in an Opti 495XLC board.
There's a Microsoft support notice about it causing hangs with some versions of Windows 9x, which gave me the clue. You'll lose the use of the turbo switch, though.
Reply 11 of 15, by maxrate
Sorry for extremely late reply everyone. I found the problem after all. The motherboard settings (jumpers) were incorrect. I am using a Intel DX4-100 overdrive chip, the settings were for another CPU. The table on how the jumpers should be set was a little misleading in terms of the way it was organized. Good lesson for me! Thankfully, nothing bad happened to the CPU. DOOM runs perfectly - no crashes. Thanks to everyone whom made suggestions.
Reply 12 of 15, by keenmaster486
Nice to hear! Now post a thread with specs, pics, and info on how you built it 😁
Reply 13 of 15, by Beerfloat
Alex_C wrote on 2016-10-18, 19:57:
Apologies for necro but I just needed to say thanks for that helpful suggestion!
I'd swapped CPU, video card, IDE controller, RAM, cache chips and PSU as well as untold BIOS and jumper settings trying to get my 495SLC board to not crash starting Doom with some variation of an 'internal stack overflow' (error message not always visible).
Disabling "Turbo Switch Function" is actually a thing, which fixed a problem. Who woulda thunk it?
Reply 14 of 15, by Alex_C
Weird, right? Glad it helped!
Reply 15 of 15, by sp3hybrid
Alex_C wrote on 2024-07-19, 21:51:
I just had the same problem on my 495SCL board with Doom crashing (and only Doom). Disabling the turbo switch feature in the bios fixed this. Thank you for posting this solution. What a strange issue.
