First post, by syndicator
When i install the YMF724 Sound card it installs the drivers for the sound card but once i gets to the YAMAHA DS-XG Legacy Sound System it bsods i have turned off all the extra including on board audio controller but i keep getting a bsod on windows 98 with the VxD drivers from this web site..My motherboard is 775i65g r3.0
Reply 2 of 3, by Stretch
I have that same motherboard and I would get the BSOD as well with my Waveforce 192.
The solution for me was the swap the card with a Guillemot Fortissimo because its drivers use IRQ 7 for the SB emulation, whereas the Yamaha drivers use IRQ 5.
If you can figure out how to mod the drivers to use IRQ 7 then maybe the BSOD problem will go away.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Cubilux 7.1 USB
Reply 3 of 3, by SaxxonPike
I had to install Windows 98 with PnP disabled. For some reason, the chipset drivers were conflicting with the legacy DSXG driver.
Setup.exe /is /ix /p i
I think someone told me to do this because of some kind of AHCI problem.
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
